temperature gauge not working
Posted: Tue Aug 16, 2022 7:38 pm
by alvera
Went out today in my 1850 auto after a three month lay up. All good except the temperature gauge is now not working. Reading on here various cures for this but they all seem to relate to wrong readings. My problem is it's not working at all so I don't know what to check first.Any help appreciated.Alan
Re: temperature gauge not working
Posted: Tue Aug 16, 2022 7:51 pm
First step is to test the sender. Earth the wire that is connected to the sender on any handy bit of nearby engine metal. Switch the ignition on, if the guage rises to full hot, the rest of the system is good and the sender is duff. Which is the most likely fault.
Posted: Wed Aug 17, 2022 12:59 am
by alvera
Thanks Steve I'll try that tomorrow.
Posted: Wed Aug 17, 2022 4:39 pm
by alvera
Hi Steve, I have done the test you suggested and the gauge went up so I have ordered a new one and hope that cures it. Thanks again Alan
Posted: Wed Aug 17, 2022 9:11 pm
by Richard the old one
It might just be that you have developed a bad connection at the sender so I would check that first by giving both bits a good clean.
Posted: Wed Aug 17, 2022 10:13 pm
by alvera
Richard the old one wrote: Wed Aug 17, 2022 9:11 pm It might just be that you have developed a bad connection at the sender so I would check that first by giving both bits a good clean.
Yes thanks for that I did spray some WD on the connection first but to no avail Alan
Posted: Fri Aug 19, 2022 7:13 pm
by alvera
Fitted the new sender today still not working, so as Richard suggested I crimped the lucar connector and now it works , so probably didn't need a new one so I have now a spare , thanks for your help. Alan
