Wanted...early seat belt anchor assembly...
shaunroche
#1 Post by shaunroche »
I'm after an early seatbelt anchor assembly such as the one shown below...it's part number is ..717980
As you can see, the one I have had been eaten by mice!
Re: Wanted...early seat belt anchor assembly...
#2 Post by xvivalve »
I think I have one in the lock up Shaun, are you going to TDCIR next week?
shaunroche
#3 Post by shaunroche »
xvivalve wrote: โ†‘Sun Aug 28, 2022 11:06 pm I think I have one in the lock up Shaun, are you going to TDCIR next week?
Hi Alun, trust you're well?
No I'm busy every weekend for the next four weeks and can't make it unfortunately!
If you could have a look and get back to me I'd be very grateful as you know!
๐Ÿ‘
new to this
#4 Post by new to this »
There the same as used on early stags, Theres a GUY tony white that brakes stags 07830 226461
shaunroche
#5 Post by shaunroche »
new to this wrote: โ†‘Mon Aug 29, 2022 10:31 am There the same as used on early stags, Theres a GUY tony white that brakes stags 07830 226461
Cheers Dave, I'll give him a go ๐Ÿ‘
shaunroche
#6 Post by shaunroche »
new to this
#7 Post by new to this »
shaunroche wrote: โ†‘Mon Aug 29, 2022 1:37 pm
On my car I've also used the stag rear console, it covers round the seat belt buckle
#8 Post by xvivalve »
I had a good look this afternoon, but could only find complete belt sets. I thought I had a spare mount block, but may have let someone have it a while ago.
PaulB
#9 Post by PaulB »
Hi Shaun,
I have a NOS one if you wish.
Regards, Paul.
shaunroche
#10 Post by shaunroche »
PaulB wrote: โ†‘Wed Aug 31, 2022 4:09 pm Hi Shaun,
Regards, Paul.
Absolutely Paul, that would be superb thank you!
#11 Post by xvivalve »
Check it works with your belts...I just tried a mix and match of the sets I have to make a good set out of two and found there are very subtle differences in the belt ends to prevent me doing so! :roll:
Mind you, one of my blocks has black release buttons, the other has red!
shaunroche
#12 Post by shaunroche »
xvivalve wrote: โ†‘Wed Aug 31, 2022 9:55 pm Check it works with your belts...I just tried a mix and match of the sets I have to make a good set out of two and found there are very subtle differences in the belt ends to prevent me doing so! :roll:
Well, it's not like BL to make things easy is it?!
new to this
#13 Post by new to this »
those seat belt blocks came with white or black buttons, the red button one i think is a after market one, ive got both red and black ones there inter changeable, the belt buckles also came with two hole or one big hole, i had some new buckles made
