Anti roll bar
Anti roll bar
Looking online I can find front ARB links, bushes, etc, but no actual bar itself?
Where does one go about sourcing one?
1972 Toledo 4 door "Betty"
Re: Anti roll bar
I have a spare, or two…
Shipping is likely to be disproportionate though
Re: Anti roll bar
Same here, in Aberdeen Scotland if you want!
Aberdeen
Re: Anti roll bar
I have a spare one in Hampshire.
Re: Anti roll bar
Not much closer to NZ Tony, but admittedly a bit!
I fear we might be taunting him slightly by showing they're available literally the length of the UK!!
Re: Anti roll bar
I couldn't see a location, thought I'd add to the post, as you say we can pretty much cover the UK.
Re: Anti roll bar
Yep, I've got a couple too.
Re: Anti roll bar
Just to rub it in some more I also have a pair.
After swapping mine to rod ends.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
Re: Anti roll bar
So basically need to source one second hand, from a Dolomite that was fitted with one from the factory?
I knew I should have bought that 1850 locally here in NZfor $600...
