THERMOSTAT HOUSING BRASS FILLER PLUG Socket/Spanner Size
jlan1978
#1 Post by jlan1978 »
Hi all
I trying to loosen the THERMOSTAT HOUSING BRASS FILLER PLUG I can't sen to find a spanner or socket to fit correctly 21 is close but the nut is very tight and i don't want to ring/force or break anything.
Can you recommend correct size please?
Re: THERMOSTAT HOUSING BRASS FILLER PLUG Socket/Spanner Size
#2 Post by xvivalve »
It should be 13/16"
jlan1978
#3 Post by jlan1978 »
Thanks i'll try that
#4 Post by Carledo »
It is 13/16" as Alun says, the size of a standard spark plug socket!
