Quarter lights
Quarter lights
Is there a way to adjust the tension/resistance on the quarter lights. Mine close at anything above 20 mph. It’s gets very hot here in Denver. The airflow from the quarter lights help a bit.
Re: Quarter lights
that will be because the plastic/nylon clamp that provides the resistance has broken, a very common age related fault.
Re: Quarter lights
^ what Alan said.
It's located at the bottom of the pivot inside the door. I think I recall Polly Booker experimenting with 3d printed replacements some years ago, but don't know if they were successful or not...Polly? Paul?
Re: Quarter lights
Yes my wife Polly did make them on her 3D printer and I have used several on different projects.
However, they are now available from Chris Witor.
https://www.chriswitor.com/proddetail.php?prod=625612RM
Re: Quarter lights
Thanks for the advice. I will order a set.
