Good afternoon all,
I am gathering parts for the restoration of my sprint which I am of course doing in stages. Working from the rear I have ordered a boot floor panel from Rimmer bros which does not cover the complete area. Reading some late posts it seems to be an issue with this part. I have contacted rimmer brothers and they say this is the only boot floor panel they do.
I have noticed that there are some repair panels for the boot but I would like to know how much of the boot they cover. They cover o/s and n/s but it would be nice to know how far inwards they fit and if they cover the width of the actual boot.
I hope this has made sense and if anyone can help I would appreciate it.
Boot floor
Re: Boot floor
Have a look here at panel B:
https://postlmg.cc/9R41Pf86
The two side panels extend up to the tank well and spare wheel well respectively. We also have a circular concave panel spun that can be used to repair the spare wheel well, but that has yet to be pictured.
Re: Boot floor
Cancel your order with Rimmers if its the full floor you've ordered. Their attempt at creating the bowl under the fuel tank is awful. Forgivable for a concealed part but you can clearly see it from the rear of our cars. If its just the area where the floor meets the wings the club repair panels will do nicely. If your undertank area needs repair then you'd do far better securing a second hand one.
1977 1850 HL manual O/D
Re: Boot floor
Hi
I fitted a Rammers boot panel, and wish I hadn't at the time as the bowl for the tank is so wrong I had to make spacers to raise the back of the tank an inch!
My whole floor was gone, but it its the edges just use the club panels, far better.
Regards
Barry
Regards
Barry
Aberdeen
Re: Boot floor
Hi everyone
Thanks for your replies and I will be sending back the rimmer brothers item. The damage is mostly in the corners and the repair items should do the trick.
There are a couple of pin holes in the centre of the boot area but I think these can be sorted out without any problems.
Thanks again
Thanks again
