I am refurbish all the suspension etc while I have the subframe out.
I have some very old, but unused ball joints that I will regreased with my trusty old saucepan of grease and camping stove (I decided using the cooker would have been too risky)
I have some new boots, the ones of the lower joints are a good fit, but the upper joints are a problem. As in loose around the small end. These may have come from the club?
Are there any well fitting ones available?
Ballpjoint boots
Ballpjoint boots
Re: Ballpjoint boots
Hi, I had the same problem and the ones I got from the club turned out to be track rod end boots, far too small. The club offered to refund but I kept them. I looked on ebay and the nearest ones I could find were 18.5 at the small end and 39mm at big end. I checked a brand new upper balljoint and that was fitted with an 18 x 40 which to be honest was a bit short and was fully stretched when the ball joint was moved fully to one side, though that probably will never happen in use. Anyway I fitted one of the 18.5 x 39mm boots and it fits well, though a bit slack in the pin the pin is tapered and when pressed fully down by the upright when tightened on seems to make a good enough seal. Chances are these are the same boots as supplied by the club.
There are some silicone 18x40mm available from a chap in Bulgaria for £8 a pair with free postage but I don`t know what they are like.
Ralph
Ralph
