Corsa C Steering Cloumn
new to this
Corsa D steering Column
#1 Post by new to this »
Any one know much about Corsa D electric steering column how big is the motor ? are they smaller than the Corsa C set up
Thanks Dave
Jod Clark
Re: Corsa D steering Column
#2 Post by Jod Clark »
Yes its bigger than Corsa C, broadly the same as the 2006> Fiat Punto unit, the Corsa D being a Punto in a different jacket.
new to this
#3 Post by new to this »
Jod Clark wrote: Sun Mar 17, 2024 9:03 am Yes its bigger than Corsa C, broadly the same as the 2006> Fiat Punto unit, the Corsa D being a Punto in a different jacket.
Thanks for the information, do you know any electric steering columns with a smaller motor than Corsa C ?
Jod Clark
#4 Post by Jod Clark »
Possibly Fiat Seicento, if you can find one...
new to this
#5 Post by new to this »
On the Corsa C steering column, there's a ECU that's mounted round the column, does that get hot,? on the back of the ECU there's fins are they a heat sink or just the grip to mount round the column ?
Thanks Dave
new to this
Re: Corsa C Steering Cloumn
#6 Post by new to this »
new to this wrote: Sun Jun 09, 2024 12:39 pm On the Corsa C steering column, there's a ECU that's mounted round the column, does that get hot,? on the back of the ECU there's fins are they a heat sink or just the grip to mount round the column ?
Thanks Dave
It turns out its just the mount to go round the steering column, but still cant work out how to remove it from the ECU
