Hi Guys,
I am going to fit an oil pressure gauge to my Sprint.
What pressure should I expect hot and cold? on idle and 3000 rpm.
Oil Pressure
Re: Oil Pressure
The official number is 50psi at 2000rpm stinking hot.
A good engine will show 60psi @ 3000 rpm and maybe 40psi @ idle cold. 50-60psi @ 3000rpm and around 20psi @ idle hot.
If it shows MORE than 60 psi under any conditions, (I've seen one that produced upward of 80psi, just before it blew it's modified spin-on oil filter clean off) it has the wrong spring in the oil pressure relief valve. This should be corrected ASAP, before it blows all the seals out!
HTH, Steve
HTH, Steve
Re: Oil Pressure
Thanks Steve for info
Phil
Phil
