Oil pump spring
#1 Post by Mad Mart »
TBH there's no need. You should be getting about 60 psi from a standard car and if you're not then there is a problem elsewhere.
grelley
#2 Post by grelley »
If you are going to fit an oil cooler then I would strongly suggest you also fit a thermostat into the oil cooler line, otherwise you could run into problems with the oil being too cold, which will also damage an engine.
Regds
