Posted: Sun Sep 30, 2007 8:41 pm
by Mad Mart
TBH there's no need. You should be getting about 60 psi from a standard car and if you're not then there is a problem elsewhere.
Posted: Mon Oct 01, 2007 11:47 pm
by grelley
If you are going to fit an oil cooler then I would strongly suggest you also fit a thermostat into the oil cooler line, otherwise you could run into problems with the oil being too cold, which will also damage an engine.
Regds
