Speed/Rev ratios & Speedo
My speedo doesn't work at the moment, so I was wondering whether anyone had any rev/speed convertion tables? I.e. how many revs you should be doing in a given gear at each of 30/40/50/60 mph.
Also, how do you get the cable off at the Overdrive end? I've got the other end undone easily, but I can't get the bottom undone - it looks to me like a knurled collar I have to undo? I can't get it to budge however, and I can't see by looking at the new cable how it goes on, the new one (from Rimmers) looks different at both ends to the old one, yet I've double checked the part number against their website (It's a '77 1850 with Overdrive)
Cheers,
Nick
Cheers,
Nick
I had a right kerfuffle with cables earlier this year....my donor was reputedly a '78, so I got the after 77 cable. This didn't fit. So I got the earlier one. That wasn't right earlier.
On eBay I saw one that looked the same as the one I tore off, so I bought that which worked. Think it was listed under Stag parts! Worked lovely mind...
My OD end had a small metal bracket that was screwed into the box, securing the cable end in place. May be what you have?
Does yours look similar to this:-
http://cgi.ebay.co.uk/TRIUMPH-DOLOMITE- ... 0029073527
I know the Sprint ones have a small fork type bracket with a bolt in, as per Lewis's description. Not sure if the 1850 is the same.
If you know the ratios you can use this to work it out.
http://www.kabamus.com/garage/gears.html
Neil
Neil
Gearing
is about 19mph per 1000 in top. Overdrive should be 21.5 or 23.5 dependiong on the o/d fitted. Variations for 175/70 knock off about 1/2 mph, for 185/70 add 1/2 mph.
Near as dammit from memory. There is a calulator web site somewhere for Rove SD1's that lets you type in the axle ratio and tyres to get dead on.
I use the Mintylamb click and select gear speed calculator. A very handy site that covers gearbox, diff and tyre variations. You can look up any Triumph gear ratio here.
tinweevil
tinweevil
