Rack questions...
Rack questions...
Shock horror my Tahiti 1850 has failed on a Rack...
I may have a spare...but they look identical to spit ones. The last one I bought from ex trader Bill of the late lameted 6 spares was supposed to be off a 1300 fwd and I stuck that on a b'stard 1300/1850 thing that ended up with synch1964? after returning to its original owners for a while. Sadly he broke it, oh well...
Anyway I digress...it drove okay like that and I didnt notice any real difference in lock or steering ratio while I had it.
So whats the story on these racks...are they all the same? Or was Bill up the creek and sold me a proper one?
And where can I get the inner track rod end to repair this one...?
Is a spit/herald one the same?
I know these are the sort of Q's I usually answer but bizarelly I've had very little rack trouble over the years.
rack
As a rule of thumb if it fts and works, cant se an issue. As you are aware, there are steering stops on the fwd models and the mounts look the same. I'm sure the guts are identical of any car, certainly of ST manufacture. Play in the end of the track rod? You cna shim them if I recall, save pulling the old one off
As usual...
the thread meanders into the irrelevent...
My own fault I suppose....
Anyone got any idea if a Spit, 1300/1500 or dolly racks have different ratios as per original Q....
Thanks slant I'll have a look at the book re shimming one...
I have on with minimal play that failed and one with about an inch that is bound to!
Oh well....
I managed to seperate the joint from the rack in about 10 minutes....
but getting the joint apart has defeated me after an hour...
I dont have a socket the size of the inner nut...so I cant seprate the joint.
The open ender is going to round the nut off so I'll take it to a friendly garage on Monday...
- David6214
this any good to you?
David but thats the outer track rod end. My problem is with the inner....
- David6214
I think the racks are all the same (someone more knowledgeable than me said so only today)
£47.00 in rimmers
http://www.rimmerbros.co.uk/cgi-bin/rim ... e/steering
or £15 for a used rack at quillers
http://www.triumphshop.co.uk/Quiller/Parts/parts.htm
Maybe less effort than fixing yours?
Jonners, shame you don't subscribe to Dolly Mixture. Richard Old produced a full write up on how he stripped and refurbished a rack, successfully, what bits were needed and where he got them from. Without looking, IIRC the cost amounted to approx the same as a recon rack, difference is you know exactly what went in as new and what didn't.
IIRC Richard was feeling a bit let down by the longevity of so called 'recon racks'
In an earlier issue, Steve Waldenberg also stripped a rack and outline the procedure.
IIRC, Herald Racks have a higer ratio, thus lock to lock is fewer rurns. Dunno about Spits. Basic rack is the same I seem to think, just length rack arms and the ratio.
Quick check on the Rimmer's site show's the Herald and Spitfire using the same rack.
With a higher Ratio option on the Spitfire only.
Vitesse show's a different part number
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
I remember
old Richards article well....and it was reproduced here so is maybe in the archive.
Ive sourced some shims and ball joint cups from Fitchetts but they only do the 10 thou ones, not the 4 and 2. They've had TR6 ones remade cos the outer track arm is shorter. They have enough core for dolomites and want 43 quid for an exchange rack now, soon going up.
