Sierra Brake mod
Sierra Brake mod
Have spoke about this before but am now actually serious about getting it done to my car. Brake fade is a real problem with my car/driving.
Have a mate who works for days whos going to inquire about the sierra parts. What about caliper brackets? Isn't there someone making them, Phil or someone you know??? How much would a pair cost me?
Adam
Adam
Don't forget, you need the your hubs turned down and the Sierra discs drilled for corect PCD & the centres machined to take the hubs, set of calipers from the scrappy plus the brackets. All in it will cost around £200. Jon maybe able to do the brackets & machining for about £90 plus P&P.
Adam, did I not send you all the gumph on how to do the conversion? You need to make up a copper pipe 350mm. long with the standard fitting on one end & 10mm. fitting on the other.
Jon is the chap that designed the conversion, he lives in the Hampshire area.
To be honest Adam & knowing your situation ie. Student, you'd be better off spending your money elsewhere on the car.
I did ask my Machine Man this a while ago (Price ETC).
I'm phoneing him over the weekend I'll jog his memory.
](./images/smilies/eusa_wall.gif)
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
I'm talking about single track lanes where your (un) lucky to have 100 metres between straights... I can drive them easily enough. My car draws the line way before I do!!!
You may mock and think I drive like a twat... but I do drive thse lanes way beyond what these cars were designed with in mind. If I don't get them then I'll get bored...
Or maybe what I will have tommorrow will solve it
watch this space
