Go on then. How do you get the downpipe off a sprint
Posted: Fri Jan 05, 2007 10:32 am
by iandollysprint
Replacing my stainless steel sprint system for a 2inch rimmers sport one.
Taking the sytem apart carefully from the rear is a dodle but how on earth do you get the down pipe off the manifold?
Do you have to remove the starter to get access to the nuts? It was a bit dark in the garage last night looking from underneath but it didn't seem obvious to me.
Any help would be appreciated.
Ian
Posted: Fri Jan 05, 2007 10:40 am
by Lewis
I took the starter off mine when I took the whole manifold off......one of the bolts sheared off.
Sorry, can't remember any more than that :(
Posted: Fri Jan 05, 2007 11:37 am
by tinweevil
Remove the heater fan and do it from above. Two are fairly easy of access then. You'll only get the ring end of a combination spanner in there so hope and pray they are studs and brass nuts not the steeeeeeeupid OE bolts.
Tinweevil
Why take it off?
Posted: Fri Jan 05, 2007 12:09 pm
by Jon Tilson
If it is sound, has a good condition end and isnt blowing at the manifold flange just leave it in place and fit the exhaust to your downpipe with a reducer.
You wont notice any difference in power and you can leave the downpipe until it really needs changing. In the mean time give it some plus gas on the bolts...think about sourcing a spare manifold for when it has to come off.
Posted: Fri Jan 05, 2007 6:42 pm
by Dollyboy
mine had sh1tty bolts, sheared the middle one, mr speedy kindly re-helicoiled and fitted nice new studs with brass nuts... proper job!
:D
ps - mine was off the car so not sure about access. my access will possibly be more difficult when the job's done anyway, hi torque starter and weird sump with wings, meaning engine out to get starter off!
Posted: Fri Jan 05, 2007 7:08 pm
by 2F45T4U
I spend half the time driving round with only one starter bolt, bottom one always buggers off!
Hey Kev why not use one of thos flexi drives for drills and mount the starter somewhere more convenient :lol:
Thats why...
Posted: Sat Jan 06, 2007 3:28 pm
by Jon Tilson
them bolts are fitted with a plain and spring washer. They dont come off then...
Posted: Sat Jan 06, 2007 4:14 pm
by melj
Good question and related to one I was going to post!
I intend to replace the downpipe on my 1500 fwd in the very near future (has to be done, pretty noisy) and was also wondering on the best methods to make sure the manifold studs don't shear off. It's extreeeemely rusty there.
The middle and rear were already replaced with s/s when I bought it, leaving me with the tricky bit!
Posted: Tue Jan 09, 2007 8:42 pm
by iandollysprint
tinweevil wrote:Remove the heater fan and do it from above. Two are fairly easy of access then. You'll only get the ring end of a combination spanner in there so hope and pray they are studs and brass nuts not the steeeeeeeupid OE bolts.
Tinweevil
Used your method. Came off easily!
Complete Standard stainless steel exhaust is now on ebay.
Cant find it...
Posted: Wed Jan 10, 2007 9:33 am
by Jon Tilson
I could be up for that...
pm me if you like...
