Attn Alun - 4 branch
SMIFTER
Re: who then
#16 Post by SMIFTER » Thu Sep 25, 2003 10:33 pm
As in all walks of life anyone is only as good as their last job.<br>
You can only speak as you find.
<p><!--EZCODE LINK START--><a href="http://www.smifter1971.pwp.blueyonder.c ... >Smifter's Dolomite Sprint Website</a><!--EZCODE LINK END--></p><i></i>
ALG1K
#17 Post by ALG1K » Fri Sep 26, 2003 9:59 pm
FYI, his workshops are at Honiley, near Balsall Common, Warwickshire. <br>
That was his old place he has moved !, A5 Nuneaton.
jon pountney
Honiley
#18 Post by jon pountney » Mon Sep 29, 2003 4:46 pm
Our dog was once taken to Honiley dog pound.
SMIFTER
Re: Honiley
#19 Post by SMIFTER » Mon Sep 29, 2003 8:10 pm
here we go - photo time!<br>
<!--EZCODE AUTOLINK START--><a href="http://www.smifter1971.pwp.blueyonder.c ... <!--EZCODE AUTOLINK END--><br>
and the best is last<br>
SprintV8
Somewhere to keep the toast Warm
#20 Post by SprintV8 » Mon Sep 29, 2003 8:25 pm
That is some Exhaust,<br>
Thought mine went round the House's
I like....
#21 Post by Jon Tilson » Mon Sep 29, 2003 9:01 pm
the way the oil cooler is connected to the steering linkage so it turns in the direction of the air flow....<br>
or am I missing something?<br>
I think he out to get out more....<br>
Jod Clark
Re: I dont like....
#22 Post by Jod Clark » Mon Sep 29, 2003 9:07 pm
... the welding on the anti-roll bar bracketry.<br>
Jod
bodgerben
I like the ideas....
#23 Post by bodgerben » Mon Sep 29, 2003 10:08 pm
"the way the oil cooler is connected to the steering linkage so it turns in the direction of the air flow....<br>
or am I missing something?" - Hmmm methinks you should have another look - its just the mounts.<br>
Well done Smifter - good pics - (not too worried about pretty welds for a track car, but they could be a little bit neater) I do like the easily adjustable anti-roll bar, and oil cooler mounts, and big sump, and side exit exhaust, and manifold and...<br>
Missing something...
#24 Post by Jon Tilson » Tue Sep 30, 2003 11:03 am
I know its seomtimes isnt obvious in print but I was trying to be funny....<br>
Oh welll some you win etc...<br>
I still think he needs to get out more...:-)<br>
SMIFTER
Re: Missing something...
#25 Post by SMIFTER » Tue Sep 30, 2003 1:47 pm
i think maybe i've been getting out too much in the past- my brains are shot away and can't think of anything but dolomites.<br>
eat Dolomites<!--EZCODE EMOTICON START :hat --><img src=http://www.ezboard.com/intl/aenglish/im ... s/pimp.gif ALT=":hat"><!--EZCODE EMOTICON END--> , sleep Dolomites<!--EZCODE EMOTICON START :hat --><img src=http://www.ezboard.com/intl/aenglish/im ... s/pimp.gif ALT=":hat"><!--EZCODE EMOTICON END--> , live Dolomites<!--EZCODE EMOTICON START :hat --><img src=http://www.ezboard.com/intl/aenglish/im ... s/pimp.gif ALT=":hat"><!--EZCODE EMOTICON END--> .<br>
Serve I a Dolomite landlord. Nurse crank up the voltage.<!--EZCODE EMOTICON START :x --><img src=http://www.ezboard.com/intl/aenglish/im ... s/sick.gif ALT=":x"><!--EZCODE EMOTICON END--> <!--EZCODE EMOTICON START :x --><img src=http://www.ezboard.com/intl/aenglish/im ... s/sick.gif ALT=":x"><!--EZCODE EMOTICON END--> <br>
bar
#26 Post by Dave » Tue Sep 30, 2003 8:24 pm
Looking at that set up, it looks like you have an option of two positions, the two small holes, in the plate at the lower arm end. then the plate is welded to a straight tube which is mounted via blocks to the original roll bar mountings on the subframe. Does that sound right?<br>
That tube is a LOT thicker than the standard bar any Idea how much Smifter?
Stephen Grellet
Exhaust
#27 Post by Stephen Grellet » Tue Sep 30, 2003 9:40 pm
What a great looking manifold. I hope it works as well as it looks. Just one comment re the anti roll bar. The pickup point on the lower arm is too close to the suspension pivot points and will not be very effectivedue to the limited movement it will see. Ideally the pickup should be mounted at the outer ball joints. I have extended the top arm spring brackets and mounted the pick up there.
SMIFTER
Re: Exhaust
#28 Post by SMIFTER » Tue Sep 30, 2003 10:45 pm
Dave - I think the bar was about 30mm ish diameter.<br>
Stephen - I'd be interested in seeing any pics of your roll bar pick up. Presumably the extension is off the triangular plate??
sprint16v
Re: Exhaust
#29 Post by sprint16v » Wed Oct 01, 2003 9:00 pm
Good point Stephen hadn't noticed that it didn't use the same mounting point at the outer end. Odd to go to all that trouble and move the attachment inboard. Whats that on the end of the bar as well some sort of rubber donut?
MaddMart
#30 Post by MaddMart » Wed Oct 01, 2003 9:30 pm
Not trying to be too thick here, <!--EZCODE EMOTICON START :p --><img src=http://www.ezboard.com/intl/aenglish/im ... tongue.gif ALT=":p"><!--EZCODE EMOTICON END--> but what has this setup achieved over the std setup ?
<p>1974 French Blue Sprint<br>
1979 Brooklands Green Sprint</p><i></i>
Locked
