lightened flywheel
Locked
ddu
lightened flywheel
#1 Post by ddu » Sat Apr 22, 2006 8:17 pm
engine going back together soon ready for paint ect,<br>
is is worth getting the flywheel lightened while its off?<br>
wont cost me anything to get done but need to know limits to m/c to ect,is it just made thinner or do you put holes in it????
SprintV8
Re: lightened flywheel
#2 Post by SprintV8 » Sat Apr 22, 2006 9:51 pm
Didn't Jod have a Lighten Flywheel 4 sale,
<p>1980 Dolomite SprintV8 (Soon to be shoehorned with a 360bhp of TVR AJP V8 Pumping Alloy !)<br>
http://www.triumphowners.com/310 </p><i></i>
Carsreunited
#3 Post by Carsreunited » Sat Apr 22, 2006 10:42 pm
Mine weighs 8.2 kilos if that helps. Not sure where the metal was removed.<br>
Silvery
Legless
#4 Post by Silvery » Sat Apr 22, 2006 10:46 pm
If getting it done, get it done by someone that knows how to do it... I personally find I'm very attached to my feet...<br>
I think the way to go is to take the metal from the outer area, as the further out the mass, the more it takes to speed up/ slow down, as well as it's supporting less other metal pulling on it (and so is less likely to give way and result in bits of flywheel through car/ flesh).
Jod Clark
Re: Legless
#5 Post by Jod Clark » Mon Apr 24, 2006 7:41 pm
Yep, lightened flywheel here. Refaced too and ready to fit, but I'm not going to post it anywhere, collect only...<br>
Jod
Too far...
#6 Post by Jon Tilson » Tue Apr 25, 2006 9:38 am
A lightened flywheel is a mixed blessing and can remove all torque from the engine or push the power band up too high...<br>
The straight sixes are particularly prone to this and some experimenters have produced some notably gutless injected 2.5 sixes....I was talking to Karl Dandrige yesterday...he had one that did nothiong below 5k rpm. Fat lot of use on a road car..especially when the long stroke six is nominally red lined at the same speed!. Given the small four's similarities I suspect the same is true. With a cast iron head and a long stroke under bearinged bottom end you dont want to be spending much time above 4k anyway...<br>
Jonners<br>
ddu
flywheel
#7 Post by ddu » Tue Apr 25, 2006 12:17 pm
thanks 4 comments..<br>
Ill leave be..
Carl
Lightened flywheel
#8 Post by Carl » Tue Apr 25, 2006 7:20 pm
I have a mildly lightened one on my car. I think there's about 2.5kg of metal removed. Tickover is perhaps a little less smooth but on the whole, performance seemed noticeably sharper after I fitted it. <br>
Jon, I'd be interested in a fuller explanation for effects you described.
MaddMart
Re: Lightened flywheel
#9 Post by MaddMart » Tue Apr 25, 2006 8:03 pm
Have a look at Bodgerben's website, he has one & can probably shed a bit more light on what the pros & cons are.<br>
<!--EZCODE LINK START--><a href="http://www.dollysprint.com/engine.htm" target="top">Bodgerben</a><!--EZCODE LINK END-->
<p>Martin<br>
LewisK
#10 Post by LewisK » Wed Apr 26, 2006 7:51 pm
Hmm. I'll be putting my AP Racing clutch plate in soon. Maybe I'll take my 'wheel down my local modification place and see what they suggest.<br>
Any clutch bits that I'll need to accumulate before doing this - seeing as I'm only changing the friction plate.
SprintV8
#11 Post by SprintV8 » Wed Apr 26, 2006 8:27 pm
Normal road use no more than a couple of pound's.<!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/images/emoticons/wink.gif ALT=";)"><!--EZCODE EMOTICON END--> <br>
And get it rebalanced as well.<br>
1lb of the flywheel is the same as removing 10lb off the car.<br>
Change the complete clutch waste of time and money just doing the Friction plate<!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/images/emoticons/wink.gif ALT=";)"><!--EZCODE EMOTICON END--> .
LewisK
#12 Post by LewisK » Wed Apr 26, 2006 8:35 pm
Ta. Thought as much <!--EZCODE EMOTICON START :hat --><img src=http://www.ezboard.com/images/emoticons/pimp.gif ALT=":hat"><!--EZCODE EMOTICON END-->
Locked
Users browsing this forum: No registered users and 8 guests
