clonking noise
Locked
ecurie
clonking noise
#1 Post by ecurie » Mon Mar 29, 2004 1:09 pm
When turning the steering wheel to the right, I've got a loud clonking noise coming from somewhere in front of my feet. I can wind the steering back and return to the right without the noise reappearing.<br>
Only when turning left, the clonking noise will reoccur, only more feeble.<br>
When I drive very slowly or when I am turning the steering wheel when standing still, I can't hear anything, which makes it very difficult to locate the noise.<br>
All bushes have been replaced with nylon bushes, as have the balljoints.<br>
Any ideas ?<br>
Benoit<br>
I Think...
#2 Post by Jon Tilson » Mon Mar 29, 2004 3:25 pm
it could be the rack mounting rubbers or intermedaiet shaft.<br>
The MoT man will find it if its dodgy..<br>
ecurie
Re: clonking noise
#3 Post by ecurie » Mon Mar 29, 2004 4:15 pm
The rack mounting rubbers have been replaced by nylon ones. Also, I don't feel anything abnormal through the steering wheel, but I can feel the clonking noise through the floorboard.<br>
As for the MOT, here in Belgium, once a car is 25 years old, it doesn't have to go through an annual test.
AndyS
Re: clonking noise
#4 Post by AndyS » Mon Mar 29, 2004 4:18 pm
Interesting, I get the same 'clonk' when I reverse off my driveway whilst turning left. After that, I never get it again.
BDN712V
MOT!?!?!?
#5 Post by BDN712V » Mon Mar 29, 2004 4:30 pm
Wow!! Surely that idea is a bit insane though??<br>
Tim
ecurie
Re: clonking noise
#6 Post by ecurie » Mon Mar 29, 2004 6:26 pm
Re : No Mot.<br>
Once the car is 25 years old you just have to present the car at an official test centre : they will inspect the chassis number, see if the car has a warning triangle and see if the car has a braking system (they will NOT test it !!!).<br>
The noise I was reffering to sounds as if a certain suspension or steering part is building up resistance when i turn right and then suddenly goes "cloink" through. When turning left it makes a much softer sound as if settling back in place.<br>
But when turning right again it starts all over again, and again, and again.<br>
Benoit
Reg
No MOT...
#7 Post by Reg » Mon Mar 29, 2004 6:38 pm
...hee hee...great stuff...i'm moving to Belgium<!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/intl/aenglish/im ... /laugh.gif ALT=":lol"><!--EZCODE EMOTICON END-->
Richard the old one
CLONKING SOUND
#8 Post by Richard the old one » Mon Mar 29, 2004 7:47 pm
I would like to suggest that check that the mounting brackets for the front anti roll bar are not loose. <br>
I found that the nuts had come slightly loose and that the brackets were moving so when I reversed out of my drive with lock hard on and there was a dip due to the road camber I heard a clonk.
Gibbonz
Speaking of Roll Bars
#9 Post by Gibbonz » Mon Mar 29, 2004 8:21 pm
Where does one purchase new roll bar end bushes.?<br>
Have tried around in the UK and cant get.<br>
Cheers<br>
Rob Gibson<br>
New Zealand
AndyS
Re: CLONKING SOUND
#10 Post by AndyS » Mon Mar 29, 2004 8:33 pm
That sounds exactly what is happening; I'll check tomorrow.
alun n
Re: CLONKING SOUND
#11 Post by alun n » Mon Mar 29, 2004 9:37 pm
sounds possibly like a worn bulkhead bush.....
ecurie
Re.clonking noise
#12 Post by ecurie » Tue Mar 30, 2004 6:49 am
I haven't changed the rollbar end bushes as I couldn't find them.<br>
So if anyone knows who sells them I would be very grateful.<br>
Benoit
Richard the old one
Clonking noise
#13 Post by Richard the old one » Tue Mar 30, 2004 10:10 pm
My problem was not the roll bar end bushes but the two brackets fitted on the front of the sub frame.<br>
Malc
Ball Joints
#14 Post by Malc » Tue Mar 30, 2004 10:41 pm
Advice from the chaps is valid. Also check yout BJ's, these can also cause clonking. Especially the tops, I had one on XAA, completely dried out with a rusty ball, loads of free play. Check also lower shock bush, on XAA one bush had competely disintegrated, clonked and knocked like a good un
Locked
