Sprint alloy wheels - what primer ?
Locked
simonhorton
#1 Post by simonhorton » Wed Nov 23, 2005 6:00 pm
Hi,<br>
I have had my sprint alloys shot blasted.<br>
What is the best primer to use on the back and around were the tyre fits.<br>
thanks Simon
Paul
primer
#2 Post by Paul » Wed Nov 23, 2005 7:41 pm
etch primer - <!--EZCODE AUTOLINK START--><a href="http://www.bodyshopwarehouse.co.uk/shop ... <!--EZCODE AUTOLINK END-->
davepoth
Re: primer
#3 Post by davepoth » Wed Nov 23, 2005 7:43 pm
Hammerite.
blacksprint
primer
#4 Post by blacksprint » Wed Nov 23, 2005 10:19 pm
any aluminium etch primer. The yellow gear for window frames from B&Q is not bad
algtj
#5 Post by algtj » Wed Nov 23, 2005 10:54 pm
Then smoothrite (black of course)
dollyboy
Re: ^
#6 Post by dollyboy » Thu Nov 24, 2005 5:58 pm
check the wheels closely for pitting before you bother with primer, otherwise you could be spending 3 coats worth just flatting them to get the 'right' finish.<br>
use P400 to lightly flat/clean them up, then if you used 'autosol' or similar, you simply wont get a better finish.<br>
it also depends again on what was actually used to blast them.<br>
etch primer has to be the base coat, then pre-coat / primer / undercoat, then colour, then lacquer.<br>
etch primer followed by hammerite for the black bits.<br>
polishing and waxing gives a better finish on the 'silver' parts, but requires more maintenance<br>
dollyboy
Re: ^
#7 Post by dollyboy » Thu Nov 24, 2005 7:16 pm
also, before I get slammed into the ground, dont use autosol to polish them if you plan to paint them.<br>
<!--EZCODE EMOTICON START :| --><img src=http://www.ezboard.com/intl/aenglish/im ... ferent.gif ALT=":|"><!--EZCODE EMOTICON END-->
Locked
