Anyone had probs with it? Changed my carb mounts, car running a lot better, but now i cant get full throttle cos the pedal seems to only go part way. Give it some stomp then it goes all the way then stays there, engine revving like mad. The throttle linkage at the carb seems to be a bit loose and is holding the throttle open. Has anyone got a pic of how it should look, or have had the same?
sprint throttle linkage
So i take it no-one has had this prob then?
Re: sprint throttle linkage
Have a look at your bulkhead wall wheer the throttle pedal mounts; you may find it has cracked and the pedal now wanders therefore not allowing full travel...
Progression....
mechanism wears and the levers flop about and the nylon rollers wear.<br>
You can get new ones but they ain't cheap...<br>
TR7 one is very similar and may even be the same...<br>
Alun?<br>
Alun?<br>
Ok chaps, found the culprit on madmarts site. Its the throttle linkage & mounting bracket, part number: 158929. You were right jonners, levers worn and flopping about, trapping the carb linkage at full throttle and holding it open. Anybody got a spare good'un, or know where i can get one?
Silence was the reply.
