sprint throttle linkage
Locked
pmn74
#1 Post by pmn74 » Tue Sep 19, 2006 7:28 pm
Anyone had probs with it? Changed my carb mounts, car running a lot better, but now i cant get full throttle cos the pedal seems to only go part way. Give it some stomp then it goes all the way then stays there, engine revving like mad. The throttle linkage at the carb seems to be a bit loose and is holding the throttle open. Has anyone got a pic of how it should look, or have had the same?
pmn74
#2 Post by pmn74 » Wed Sep 20, 2006 6:22 pm
So i take it no-one has had this prob then?
alun n
Re: sprint throttle linkage
#3 Post by alun n » Wed Sep 20, 2006 9:51 pm
Have a look at your bulkhead wall wheer the throttle pedal mounts; you may find it has cracked and the pedal now wanders therefore not allowing full travel...
Progression....
#4 Post by Jon Tilson » Wed Sep 20, 2006 11:30 pm
mechanism wears and the levers flop about and the nylon rollers wear.<br>
You can get new ones but they ain't cheap...<br>
TR7 one is very similar and may even be the same...<br>
Alun?<br>
pmn74
#5 Post by pmn74 » Sat Sep 23, 2006 2:01 pm
Ok chaps, found the culprit on madmarts site. Its the throttle linkage & mounting bracket, part number: 158929. You were right jonners, levers worn and flopping about, trapping the carb linkage at full throttle and holding it open. Anybody got a spare good'un, or know where i can get one?
pmn74
#6 Post by pmn74 » Mon Sep 25, 2006 9:59 pm
Silence was the reply.
Locked
