radiator reconditioning ?
knightrider150
#1 Post by knightrider150 » Thu Apr 01, 2004 11:21 am
has anyone had this done ? <br>
what is changed? just the core or the whole lot looked at? <br>
im thinking of having a recore done on my rad before the summer ....its in a pretty nasty state how much am i looking at? <br>
thanks <br>
James <!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/intl/aenglish/im ... /happy.gif ALT=":D"><!--EZCODE EMOTICON END-->
dollysteve
Re: radiator reconditioning ?
#2 Post by dollysteve » Thu Apr 01, 2004 3:50 pm
When I was mechanic we used to get rads reconditioned all the time as it was quite a bit cheaper than buying brand new mazda ones, every bit as good as a new one but as I say, cheaper. They basically remove the tanks from the rad and put in a new core, after that they then flow test it and make sure it`s water tight and give it a nice new coat of paint. Personally i`ve never experienced a problem with a recon rad and have used them in a number of my own vehicles.
tdcsuffolk
Price
#3 Post by tdcsuffolk » Thu Apr 01, 2004 4:34 pm
I enquired at a local rad place near me to recore a Sprint rad, quoted me £72. <!--EZCODE EMOTICON START :eek --><img src=http://www.ezboard.com/intl/aenglish/im ... ns/eek.gif ALT=":eek"><!--EZCODE EMOTICON END--> I choked politely and hung up. I'm sure it's cheaper than that elsewhere...
redalan1971
recore
#4 Post by redalan1971 » Thu Apr 01, 2004 4:57 pm
i've had this done on two of my sprints and the cost was around £85 each time so £72 is good.
Stan Part
Re: recore
#5 Post by Stan Part » Thu Apr 01, 2004 7:33 pm
Do they replace the outer "frame" as well as mine is rotted through at the bottom where the fan has thrown road water onto it.
redalan1971
recoring
#6 Post by redalan1971 » Thu Apr 01, 2004 8:08 pm
not normally they just replace the core, but you don't get the fame if you exchange one at triumph suppliers. if it's only the bottom steel plate any metal frabricator can easily knock you up a replacement.<br>
Richard
Next DM
#7 Post by Richard » Thu Apr 01, 2004 8:59 pm
If you want a better rad, wait until you see the volvo one in the next DM....
Stagger
recore
#8 Post by Stagger » Thu Apr 01, 2004 9:00 pm
Watch that the recore is for a Sprint and not an 1850, I was caught with this many years ago.<br>
Jod Clark
Re: recore
#9 Post by Jod Clark » Thu Apr 01, 2004 9:02 pm
I would have said that £72 was reasonable. Especially if you get them to braze a boss into the tank for a leccy fan switch while they're at it...<br>
I asked my reconditioners for an 1850 Rad recore and they asked if I would accept a Sprint one instead! Wednesbury Radiator Services: 0121 502 5732<br>
Jod
<p><!--EZCODE IMAGE START--><img src="http://www.towingandleisure.co.uk/images/bash.gif" style="border:0;"/><!--EZCODE IMAGE END--></p><i>Edited by: <A HREF=http://pub52.ezboard.com/bthetriumphdol ... dclark>Jod Clark</A>  <IMG HEIGHT=10 WIDTH=10 SRC="http://www.towingandleisure.co.uk/images/bash.gif" BORDER=0> at: 1/4/04 9:04 pm<br></i>
dolly mixture ed
Re: Recore with kenlowe thermosat in it
#10 Post by dolly mixture ed » Thu Apr 01, 2004 11:20 pm
I had mine recored and modified so that it had the thermosat for my kenlowe in the offside vertical panel. I think it was bout 85 notes<br>
...but I am very tempted to try Richard's mod, see next DM.<br>
Glynn
Malc
Core Blimey
#11 Post by Malc » Thu Apr 01, 2004 11:30 pm
£72 is not bad. But as the chaps say, make sure the correct 3 row 16ish gill per inch core is used. A lot of rad builders use a 2 row core from an 1850 cos the tanks are the same. This is a definate no no in my book. It sepends on where the core is sourced from as to how much of the old rad is used. a decent core has the 'end plates and frame' already brazed to the tubes, neccessitating just the tanks to be soldered on. in this instance, the lower frame is new, all that is re-used are the tanks and the mounting brackets.
tdcsuffolk
Rad re-core price
#12 Post by tdcsuffolk » Fri Apr 02, 2004 10:08 am
Well I guess we live and learn - I've never had a rad re-cored before so was guessing £72 was a lot, but not if it's like new (or better if modified) of course. Thanks for the feedback. Will give him a ring if overheating not solved.
MaddMart
Rads
#13 Post by MaddMart » Sun Apr 11, 2004 1:38 pm
The viscous fan on my track Sprint decided to release itself from the pulley wheel on Friday with predictable results. The rad on the right is obviously a Sprint rad but what is the rad on the left. I had this as a spare in my garage loft & when I went to get it down today noticed the difference in the core design.<br>
<!--EZCODE IMAGE START--><img src="http://www.dolomitesprint.com/images/rad1.jpg" style="border:0;"/><!--EZCODE IMAGE END--><br>
<!--EZCODE IMAGE START--><img src="http://www.dolomitesprint.com/images/rad2.jpg" style="border:0;"/><!--EZCODE IMAGE END-->
<p><!--EZCODE LINK START--><a href="http://www.aqpd91.dsl.pipex.com/" target="top">Mad Mart's Website</a><!--EZCODE LINK END--></p><i></i>
Carsreunited
Aliens
#14 Post by Carsreunited » Sun Apr 11, 2004 4:07 pm
Obviously the little green men got bored with crop circles.........<br>
Check it again in the morning Martin and see if mopre complex shapes have appeared. The truth is out there!
Malc
CORE blimey FANcy that
#15 Post by Malc » Sun Apr 11, 2004 7:17 pm
Spectacular, guess you had a few revs on when it let go <!--EZCODE EMOTICON START :x --><img src=http://www.ezboard.com/intl/aenglish/im ... s/sick.gif ALT=":x"><!--EZCODE EMOTICON END--> . Hard to be precise going by only photo's, but looks like your spare rad is an 1850. These are physically the same size, but have fewer gills per inch. If it is a 3row core then chances are it is a Sprint rad that has been recored at some time with a 'less dense' core.<br>
PS I didn't bid on that viscous coupling, looks as though you need it more than me <!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/intl/aenglish/im ... s/wink.gif ALT=";)"><!--EZCODE EMOTICON END-->
Locked
