funny sprint temp gauge problem
Locked
glasgorangersfan
#1 Post by glasgorangersfan » Tue Sep 20, 2005 11:26 pm
recently i have encountered a funny situation. When starting/driving the sprint from cold,, if the heater control is at cold position, the temp gauge climbs almost to fully hot for a brief time (as engine warms) before eventually settling to "normal"....If heater control is warm/hot position this anomily doesnt occur. 1st time this happened i of coarse pulled over lifted bonnet to expect the worst,but the engine was certainly not hotter /overheating at all.??<br>
Any thoughts guys? <br>
Sandy.
Silvery
Localised
#2 Post by Silvery » Wed Sep 21, 2005 12:16 am
Sounds a bit like localised heating, the heater acting as a bypass till the thermostat opens up. Don't know Sprint plumbing, but check all the hoses are OK and not kinked or collapsed.
1300dolly
Re: Localised
#3 Post by 1300dolly » Wed Sep 21, 2005 2:04 am
and check you don't have an air lock, loosen bottom hose till you get a consent flow of water coming then retighten, maken sure you keep the rad topped up.<br>
This is the old skool way of bleeding the sytem so someone with a sprint might have a easier way.<br>
Justyn<br>
Oh forgot to say to bleed it when water is hot/thermostat open so avoid the hot water and don't forget the anti-freeze.<br>
<p></p><i>Edited by: <A HREF=http://p206.ezboard.com/bthetriumphdolo ... 00dolly</A> at: 21/9/05 2:11 am<br></i>
alun n
Re: Localised
#4 Post by alun n » Wed Sep 21, 2005 8:17 am
The temp pick up is at the other end of the system to the heater. I'd look first at your thermostat to make sure it opens properly; don't assume a new one is good, test it first. Then I'd check the thermistor itself and the voltage stabiliser...
<p>1973 Dolomite Sprint<br>
1974 Dolomite Sprint<br>
1979 Dolomite Sprint<br>
1979 Dolomite 1850HL<br>
1980 Dolomite 1500HL<br>
1998 Lotus Elise<br>
1999 Alfa Romeo 166 3.0 V6 (now for sale on ebay; 12 months MOT, finishes tomorrow)</p><i></i>
Locked
