recently i have encountered a funny situation. When starting/driving the sprint from cold,, if the heater control is at cold position, the temp gauge climbs almost to fully hot for a brief time (as engine warms) before eventually settling to "normal"....If heater control is warm/hot position this anomily doesnt occur. 1st time this happened i of coarse pulled over lifted bonnet to expect the worst,but the engine was certainly not hotter /overheating at all.??<br>
Any thoughts guys? <br>
Sandy.
funny sprint temp gauge problem
Re: Localised
and check you don't have an air lock, loosen bottom hose till you get a consent flow of water coming then retighten, maken sure you keep the rad topped up.<br>
This is the old skool way of bleeding the sytem so someone with a sprint might have a easier way.<br>
Justyn<br>
Oh forgot to say to bleed it when water is hot/thermostat open so avoid the hot water and don't forget the anti-freeze.<br>
<p></p><i>Edited by: <A HREF=http://p206.ezboard.com/bthetriumphdolo ... 00dolly</A> at: 21/9/05 2:11 am<br></i>
Justyn<br>
Re: Localised
The temp pick up is at the other end of the system to the heater. I'd look first at your thermostat to make sure it opens properly; don't assume a new one is good, test it first. Then I'd check the thermistor itself and the voltage stabiliser...
<p>1973 Dolomite Sprint<br>
1974 Dolomite Sprint<br>
1977 Dolomite Sprint (Pageant)<br>
1977 Dolomite Sprint (White)<br>
1979 Dolomite Sprint<br>
1979 Dolomite 1850HL<br>
1980 Dolomite 1500HL<br>
1998 Lotus Elise<br>
1999 Alfa Romeo 166 2.5 V6<br>
1999 Alfa Romeo 166 3.0 V6 (now for sale on ebay; 12 months MOT, finishes tomorrow)</p><i></i>
