fitting 1500 o/d into 1300 dolly
Silvery
Bribery
#16 Post by Silvery » Tue Feb 10, 2004 2:41 pm
I'm always skint too.. But if you've got an engine crane and spare bit of drive for a day or so.. Then how'd you like few beer tokens (not many as I ain't got many though!) for me to hire your "facilities" to drop that 1300 in my auto? <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/im ... /smile.gif ALT=":)"><!--EZCODE EMOTICON END--> I haven't found a cheap hoist yet, am loathed to hire one for 50 quid for the week, and even more loathed to do the engine swap near the garage where my 1300 got trashed, in case I don't get it done in a day <!--EZCODE EMOTICON START :( --><img src=http://www.ezboard.com/intl/aenglish/im ... /frown.gif ALT=":("><!--EZCODE EMOTICON END--> <br>
Katy's old 1300 lump should be a good one, and I did get seats too, but it was still a long drive (although had a good laugh and a coffee, so not all bad <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/im ... /smile.gif ALT=":)"><!--EZCODE EMOTICON END--> ).<br>
Got any beige seats from an HL/ 1850? Can p/x for beige Dolly 1300 seats in good nick - Got them for the fwd, but found out I need to drill the floor to fit them <!--EZCODE EMOTICON START :( --><img src=http://www.ezboard.com/intl/aenglish/im ... /frown.gif ALT=":("><!--EZCODE EMOTICON END-->
C Mallock
splines
#17 Post by C Mallock » Wed Feb 11, 2004 12:07 am
how many teeth should a 1500 (76) od box have? as my clutch went on the way to stoneleigh and i brought one of the first stand a saw, now have a nasty feeling that it might not be right
IRL1177NI
#18 Post by IRL1177NI » Wed Feb 11, 2004 9:23 am
From memory I think its 21 or could be 23 with 1 in dia shaft
C Mallock
clutch
#19 Post by C Mallock » Wed Feb 11, 2004 10:45 am
Thanks for that it means i have the right one
BDN712V
2000 o/d into 1500??
#20 Post by BDN712V » Wed Feb 11, 2004 7:37 pm
Found one on e-bay and am wondering whether it is feasible or not, as I am unable to trace any part numbers to check whether they match up...<br>
Tim
Errr....
#21 Post by Jon Tilson » Thu Feb 12, 2004 10:52 am
The short answer is I dont know but it may not be easy.<br>
The T2000 box is the large car box as fitted to Sprints.<br>
If the bell housing lines up with the 1500 end plate u may well be in luck. But then will it pick up with the cross member? Maybe cos a Sprint box uses the same one IIRC. Also it may have the older A type overdrive.<br>
Prop shaft sliding joint may not have enough reach.<br>
The input spline count may mean you cant get a plate that fits your flywheel. You may need a Sprint tunnel to go over it.<br>
If its near you and cheap enough it may be worth a try.<br>
The std o/d box fits a Spit so prices are inflated. If this one fits you will have a bomb proof box If it doesnt you can always sell it again to a TR6 owner...<br>
alun n
Re: Errr....
#22 Post by alun n » Thu Feb 12, 2004 11:39 am
If it has the A type overdrive and it works it is worth a minimum of £300 to a TR owner!!
BDN712V
unfortunately not an a-type...
#23 Post by BDN712V » Thu Feb 12, 2004 11:49 am
D'OH!!!! That could have paid for quite a lot of materials and parts for the car....<br>
<!--EZCODE AUTOLINK START--><a href="http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... <!--EZCODE AUTOLINK END--><br>
Doesn't honestly look as though it would fit too well, but hen again, it's been a while since my gearbox was out of the car...<br>
Tim
thebouncingbunny
engine removal
#24 Post by thebouncingbunny » Fri Feb 20, 2004 6:52 pm
silvery.unfortuanately i cant offer you any drive space for engine removal-i usually do this sort of thing at my parents.i cant see me mum being too chuffed.she nearly had me guts fer garters over the last one.as for engine hoist i usually hire one from crecent auto center in weymouth.£12 a day but you have to pick it up.its big and wont fit in a dolly boot.i reckon if you hired it on a sat youd get it till mon tho.the guys name down there is dwain.he's pretty reasonable.tell him you know his window cleaner and you might swing the weekend thing(winks knowingly)bunny<br>
if you get stuck i may be able to give you a hand if i'm about
Silvery
Hoist
#25 Post by Silvery » Fri Feb 20, 2004 7:16 pm
Cheers for that <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/im ... /smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <br>
I went to the local hire place, it's about 50 quid for a week... No chance of doing any "deals" on that either...<br>
Will have to try and sort out somewhere to do it, or leave it a few weeks until I'm not so new here, that way the neighbours might just let me get away with it in the car park!<br>
I should be able to get the job done fairly quickly on my own, didn't have a problem last time, and that time I took the auto lump out, the manual lump out, looked at the ends of the cranks (wanted to simply put the good engine out the manual in the auto), gave up, tried to get the auto lump back in, couldn't, took the lump and box out sort of loosely bolted together to lift them, piddled about a bit more, dropped the box on the engine, dropped it back in, etc. All in all alot of stuff I won't be doing this time, alot of time wasted working things out, and not much actual time with spanners.<br>
Tomorrow I'm going to be trying to move a large 3 seater sofa with my 1500 auto... If I can manage that, then who says I can't get a hoist in the boot... <!--EZCODE EMOTICON START :rollin --><img src=http://www.ezboard.com/intl/aenglish/im ... s/roll.gif ALT=":rollin"><!--EZCODE EMOTICON END--> <br>
Oh, and come summer if I've got a bit of cash, might still be looking for a few bits, if you want to clear some space and get a bit of beer money? Mail me on triumph1500tc at yahoo.co.uk if you want <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/im ... /smile.gif ALT=":)"><!--EZCODE EMOTICON END-->
Locked
Users browsing this forum: No registered users and 5 guests
