Gearbox gasket
Locked
tdcsuffolk
Gearbox gasket
#1 Post by tdcsuffolk » Wed Mar 31, 2004 11:11 am
Hi, my Sprint gearbox appears to be leaking - possibly from the gasket. Is it possible to change the gasket with the gearbox in situ, by draining and removing the bolts which hold the two sections together? I won't be trying this unless I am sure it will all go back together ok and springs and teeth are not going to fly out all over the floor and into my eyes and I crouch beneath. Removing the gearbox not possible at the mo.<br>
Apologies as always if this has already been convered in previous threads - couldn't find anything. <br>
Cheers. <!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/intl/aenglish/im ... s/wink.gif ALT=";)"><!--EZCODE EMOTICON END-->
tdcsuffolk
#2 Post by tdcsuffolk » Thu Apr 01, 2004 4:30 pm
No-one wanting to give some words of advice...? <br>
Ya boo sucks <!--EZCODE EMOTICON START :( --><img src=http://www.ezboard.com/intl/aenglish/im ... /frown.gif ALT=":("><!--EZCODE EMOTICON END-->
paulgeering
Re: ...
#3 Post by paulgeering » Thu Apr 01, 2004 9:26 pm
You don't appear 100% sure where it is leaking from. Clean thoroughly and go for a short drive and check carefully to find exactly where it is coming from. A little oil can go a very long way so be certain.<br>
An oft overlooked gasket is the one at the front end of the box - within the bell-housing - where the main shaft enters the box. You will need to remove box and cross shaft to do this one and as far as I am aware no pre-cut gasket exists for it. Affraid you will have to nick the kitchen scissors and attack a sheet of gasket material.
<p></p><i>Edited by: <A HREF=http://pub52.ezboard.com/bthetriumphdol ... geering</A> at: 1/4/04 9:35 pm<br></i>
paulgeering
Re: ...
#4 Post by paulgeering » Thu Apr 01, 2004 9:32 pm
Do you mean the seal between the box and the O/D? If you do....I have changed the O/D with the box in situ but I had the use of a pit. It was not at all easy as the O/D is extremely heavy at chest level with limited arm leverage. I will never do it again - I would take the engine and box out every time! I reckon I could do the job in half a day..but I'm not going to! <!--EZCODE EMOTICON START :smokin --><img src=http://www.ezboard.com/intl/aenglish/im ... smokin.gif ALT=":smokin"><!--EZCODE EMOTICON END-->
Oil leaks....
#5 Post by Jon Tilson » Thu Apr 01, 2004 10:11 pm
There are a few places oil can leak on a Sprint bix and I'm afraid the only way to diagnose is to give it a good clean and then fill it up and run it....<br>
Its then that you gopefully find its running out of the back of the rocker cover and it isnt gear oil at all....<br>
If it is box oil then you have some options. If its the o/d to adapter plate gasket you can chage it in situ but its a bitch. Its also extremel unlikely....but you can slide the o/d back off the mainshaft and then back on if you must. Its not an easy job and sometimes the splines can be a real git to line up...<br>
The plate at the bottom of the o/d can leak and this is an easy fix. Make sure various plungers and valves dont drop out and go walkies...<br>
If its the o/d tailshaft seal then its o/d off to fix really...<br>
If its the adaptor to gearbox seal it may respond to a tighten but its unlikely. Full box rebuild. On the single rail and 3 rail dolly boxes the exhaust mounting sometimes make these bolts work loose and then they leak. Ive sealed them with hylomar and a good tighten. I cant remember what a Sprint one looks like here.<br>
If its coming from the top selector area you can change the gasket here with the tunnel out.<br>
Obviously tighten the drain plug.<br>
If its at the engine to box joint then its the front seal and you have to have the box out.<br>
Any more advice and I'm charging you...<br>
Jonners<br>
tdcsuffolk
Ok...
#6 Post by tdcsuffolk » Fri Apr 02, 2004 9:58 am
... thanks lots for all the info. Sadly car not MOT'd so can't really go for a good run, but I will give the box a good clean and run sitting and re-check. It seems to leak even when stationary. More investigations needed methinks. Cheers. <!--EZCODE EMOTICON START : --><img src=http://www.ezboard.com/intl/aenglish/im ... ohwell.gif ALT=":"><!--EZCODE EMOTICON END-->
george
o/d removal
#7 Post by george » Fri Apr 02, 2004 1:58 pm
if you run the car rear wheels off the ground and select 3/4 engage o/d and switch off the engine and let it stop still in gear and o/d selected it comes off very easy and is easy to reinstall this method locks the o/d unit and its only the plunger collar u need to worry about when reinstalling the o/d
alun n
"By George!"
#8 Post by alun n » Fri Apr 02, 2004 2:31 pm
George, I think you need to write a book of top tips and I think I just gave you the title!<br>
Leastwise a bit of contribution to the magazine......?
george
o/d
#9 Post by george » Fri Apr 02, 2004 3:53 pm
forgot to say if you do have to strip the o/d unit <br>
we used to have a main shaft to hand to line it up <br>
prior to refitting it very handy
triumphdolomiteuk
Site Admin
Re: "By George!"
#10 Post by triumphdolomiteuk » Fri Apr 02, 2004 3:59 pm
Although a large number of our members do read the forums,quite a few members don't have computers.We're always on the lookout for technical articles for Dolly Mixture....
Locked
