1978 Dolomite 1300 RWD.Just fitted new Master and Slave together with non flexible pipe.Have bled a few times.System works ok to start with.Next day less pressure,have to double de clutch to get into gear sometimes.Reverse almost impossible without lots of pumping.Fluid level OK.Anyone any suggestions.<br>
John Wood.
Clutch Hydraulics
DailySprinter
clutch hydraulics
Somewhere you've got a leak, even new cylinders are not always perfect espacially if they have been stored for a long time. You should find fluid leaking somewhere.
Second that...
and to remind you that the bleed screw must be above the inlet pipe at the slave end, else you cant get rid of that last bubble...<br>
Dolomite Clutch Hydraulics
Many thanks for the info,will check that outRegards John
