Proposhaft help needed - sprint
Locked
iandollysprint
#1 Post by iandollysprint » Tue Jul 25, 2006 10:57 am
Just bought a dolly sprint (1974 - super bodywork, tired mechanicals). Propshaft feels as if it is about to drop off, particularly on take off in 1st. Checked the hardy spicer joints at gearbox end and axle end - they seem OK. (Thought the sprint prop only had one hardy spicer joint and 2 cv joints?).<br>
Also checked the centre bush/bearing. You can easily waggle the prop shaft about in the rubber, a lot. - should this be the case?<br>
Any recommendations for getting the propshaft rebuilt. Rimmers seem to want big money.<br>
Thanks in advance
dollysteve
Re: Proposhaft help needed - sprint
#2 Post by dollysteve » Tue Jul 25, 2006 11:28 am
You need a new centre bearing, it shouldn`t be flopping around in the rubber, try your local motor factors. I bought mine at one and it turned out to be the same as a sherpa item, as were the UJ`s.
MaddMart
#3 Post by MaddMart » Tue Jul 25, 2006 11:44 am
I've only ever had one Sprint that had two CV joints.
<p>Martin<br>
alun n
#4 Post by alun n » Tue Jul 25, 2006 1:20 pm
Is the rubber collar of the centre bearing complete? What you could also be experiencing is the axle moving about as drive is taken up; check the eight sets of bushes which are supposed to hold it in place with a big pry bar, or possibly the rear gear box mount has failed.
tinweevil
#5 Post by tinweevil » Tue Jul 25, 2006 1:23 pm
Where abouts are you?<br>
Julian.<br>
<p>1978 <!--EZCODE LINK START--><a href="http://www.triumphowners.com/704">Dolomite Sprint</a><!--EZCODE LINK END--> Blue, a bit tetley.<br>
1980 <!--EZCODE LINK START--><a href="http://www.triumphowners.com/864">Dolomite 1500HL</a><!--EZCODE LINK END--> Orange, current daily drive.</p><i></i>
iandollysprint
#6 Post by iandollysprint » Tue Jul 25, 2006 4:55 pm
Stoke-on-trent<br>
Working in Telford
iandollysprint
#7 Post by iandollysprint » Tue Jul 25, 2006 4:57 pm
I'll try the rear end bushes and axle/gearbox mounts as well. Plan is to completely rebush the car with superflex bushes.<br>
Ta<br>
Ian
tinweevil
Stoke-On-Trent
#8 Post by tinweevil » Wed Jul 26, 2006 8:40 am
Not a million miles away from me up until the 4th. If you'd like a 2nd opinion gimme a shout.<br>
Julian
1973 <!--EZCODE LINK START--><a href="http://www.triumphowners.com/755">Dolomite Sprint</a><!--EZCODE LINK END--> VA41, seriously tetley. - Current daily drive.<br>
1980 <!--EZCODE LINK START--><a href="http://www.triumphowners.com/864">Dolomite 1500HL</a><!--EZCODE LINK END--> Orange, Really quite tidy.</p><i></i>
Locked
