Investigating noises in the transmission
AndyS
Nope
#16 Post by AndyS » Thu Mar 25, 2004 12:12 pm
Too loud for the speedo cable.<br>
Come to think of it, the car is turning green! <!--EZCODE EMOTICON START :rollin --><img src=http://www.ezboard.com/intl/aenglish/im ... s/roll.gif ALT=":rollin"><!--EZCODE EMOTICON END-->
alun n
Re: Nope
#17 Post by alun n » Thu Mar 25, 2004 1:49 pm
wanna bet?<br>
they get very loud just before they give up the ghost!<br>
If its THAT loud, do you have any oil in your axle?, it may be about to gestate from a Triumph into a Singer!!
AndyS
They do?
#18 Post by AndyS » Thu Mar 25, 2004 2:32 pm
What does it sound like? is it a loud, tinny noise?<br>
Y'know, I'll end up rebuilding the bloody car at this rate just to find the damn thing! <!--EZCODE EMOTICON START >D --><img src=http://www.ezboard.com/intl/aenglish/im ... s/grin.gif ALT=" >D"><!--EZCODE EMOTICON END-->
alun n
Re: They do?
#19 Post by alun n » Thu Mar 25, 2004 2:38 pm
A spinning noise that varies with speed sort of:<br>
"tik, tik, tik, tik, tik, tik......"
AndyS
Oh right
#20 Post by AndyS » Thu Mar 25, 2004 2:55 pm
Well it's not that then, this is an intermittent clanking noise. Like you say, it would be a consistent clicking if it was the speedo.<br>
I'll disconnect the speedo anyway at some point.<br>
Oh my, I've got one of those air threshners which has a little prop which spins around when you put the blower on.........I wonder .......<!--EZCODE EMOTICON START :eek --><img src=http://www.ezboard.com/intl/aenglish/im ... ns/eek.gif ALT=":eek"><!--EZCODE EMOTICON END-->
alun n
Re: Oh right
#21 Post by alun n » Thu Mar 25, 2004 4:22 pm
Girlfriend's ear rings?
AndyS
Possibly
#22 Post by AndyS » Thu Mar 25, 2004 4:34 pm
I'll have to make sure the missus doesn't see them! <!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/intl/aenglish/im ... /laugh.gif ALT=":lol"><!--EZCODE EMOTICON END-->
AndyS
Re: Possibly
#23 Post by AndyS » Sat Mar 27, 2004 10:40 am
Right, after further investigation and with the help of the mersey tunnel (2 trips <!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/intl/aenglish/im ... /happy.gif ALT=":D"><!--EZCODE EMOTICON END--> ) and having the window down. I have found that the noise only happens when I put my foot down on the accelerator but is intermittent.<br>
But again, it's only in drive. At a stand still I can rev the car quite happily with no noise!<br>
The exhaust is very firm in its position so it can't be that.<br>
This is so strange!
Jod Clark
Re: Possibly
#24 Post by Jod Clark » Sat Mar 27, 2004 2:56 pm
Only in drive??<br>
That sounds like a torque converter issue to me. I hope it isn't.<br>
Jod<br>
AndyS
Re: Possibly
#25 Post by AndyS » Sat Mar 27, 2004 3:12 pm
Jod,<br>
would you like to elaborate a wee bit more on the torgue converter? Too be honest, I've never heard of it.<br>
Oh hold on, am I right in saying they are used on auto boxes instead of a clutch? If so, mine is a manual.
<p></p><i>Edited by: <A HREF=http://pub52.ezboard.com/bthetriumphdol ... b>AndyS</A>  <IMG HEIGHT=10 WIDTH=10 SRC="http://hometown.aol.co.uk/ASkop01/myhomepage/car1a.gif" BORDER=0> at: 27/3/04 5:12 pm<br></i>
Funny that....
#26 Post by Jon Tilson » Sat Mar 27, 2004 8:33 pm
I thought we were on an auto quest here too....<br>
My money is on the propshaft....<br>
Does it matter which gear your in,....worse or less bad on bends etc...overdrive or not?<br>
Jon
AndyS
Re: Funny that....
#27 Post by AndyS » Sat Mar 27, 2004 9:10 pm
Ooops apologies for confusing you all.<br>
The noise is on all gears (intermittently) but only when I use the accelerator. If I back off, the noise disappears. It is more noticeable in first and second. Some times it's very loud, sometimes not.<br>
I also get it if I go over bumps. Thats whats got me thinking it might be the exhaust, but is it very rigid and seems to be in order. There also seems to be vibration too!<br>
Very puzzling.
AndyS
I think I've cracked it.....
#28 Post by AndyS » Sun Mar 28, 2004 12:48 pm
Page 50(4) of my haynes.......... "Wear in the kneedle roller bearing is indicated by vibtration or 'clunks' in the transmission,particulary when the drive is being taken up!!"<br>
Well thats exactly whats happening! Is it a difficult job?
Needle rollers....
#29 Post by Jon Tilson » Mon Mar 29, 2004 10:53 am
Ususally make a whiring noise which can be heard with the car in neutral and clutch up. Layshaft and input shaft are then turning but not under much load. In 1st to third gears the noise will be much worse and may be an engine spedd related load whining that reduces when in top gear. It tends not to come and go but be constant. How is your reverse? I ask cos the selctor mounting pin sometimes works loose and lets the reverse cog touch other bits intermitently but this is very rare.<br>
Jon
AndyS
Jon
#30 Post by AndyS » Mon Mar 29, 2004 11:09 am
I've just had a recon box from those nice people at Canley, so I would have to eliminate the box. It's got to be either prop or a diff problem.
Locked
