Slick 50 NOT TO BE USED IN O/D GEARBOXES!
tdcsuffolk
#1 Post by tdcsuffolk » Mon Feb 23, 2004 3:16 pm
Is this safe for Sprint engine & gearbox? I'm assuming there's no reason for it be unsafe, but wondered if anyone had some wise thoughts. Tried doing a thread search but found nowt.<br>
Cheers<br>
<p></p><i>Edited by: <A HREF=http://p206.ezboard.com/bthetriumphdolo ... omiteuk</A> at: 19/10/06 3:05 pm<br></i>
Silvery
Slick 50
#2 Post by Silvery » Mon Feb 23, 2004 5:43 pm
Slick 50 for the engine has ptfe particles in it.<br>
Great, you might think, really slippy stuff..<br>
But no - true it's slippy stuff, but it's also pretty much just very fine grinding paste - on a worn engine it might help, or at least not do any harm, but on a nice tight engine it will slowly grind away metal from moving surfaces... Making them more slippy cause they move more freely because there's simply less surface to surface contact possible!<br>
That's the basics of what I remember about it anyway. Just use a good oil, IMO
alun n
Re: Slick 50
#3 Post by alun n » Mon Feb 23, 2004 7:15 pm
UNDER NO CIRCUMSTANCES put this into an overdrive gearbox. The overdrive relies to a certain extent on friction and slick 50 or any friction reducing additive is the last thing it needs! You will surely shag it!
tdcsuffolk
Oh
#4 Post by tdcsuffolk » Mon Feb 23, 2004 9:28 pm
Thanks for that, damn glad I checked as I was gonna pour the devil's fluid into my OD box in the next couple of days. Guess I'll stick to the EP90 then. <!--EZCODE EMOTICON START : --><img src=http://www.ezboard.com/intl/aenglish/im ... ohwell.gif ALT=":"><!--EZCODE EMOTICON END-->
anthony rld900r
slick 50
#5 Post by anthony rld900r » Tue Feb 24, 2004 2:21 pm
I've had slick 50 in my 1850 engine before, ran quieter but given the cost (even at £5 off at Halfords) still a pricey way of not putting good oil in (which would cost less<!--EZCODE EMOTICON START : --><img src=http://www.ezboard.com/intl/aenglish/im ... ohwell.gif ALT=":"><!--EZCODE EMOTICON END--> )...
Jod Clark
Re: molyslip
#6 Post by Jod Clark » Tue Feb 24, 2004 8:09 pm
Molyslip is good gear.<br>
My regular oil "concoction" is made up from 1xtub of STP, 1xtin of molyslip and top-up with 10w/50 semi synthetic.<br>
I also have a decent supply of castor oil, worth a dash in the sump just for the smell.<br>
Jod
<p><!--EZCODE IMAGE START--><img src="http://www.towingandleisure.co.uk/images/bash.gif" style="border:0;"/><!--EZCODE IMAGE END--></p><i>Edited by: <A HREF=http://pub52.ezboard.com/bthetriumphdol ... dclark>Jod Clark</A>  <IMG HEIGHT=10 WIDTH=10 SRC="http://www.towingandleisure.co.uk/images/bash.gif" BORDER=0> at: 24/2/04 8:09 pm<br></i>
molyslip
#7 Post by Dave » Tue Feb 24, 2004 8:13 pm
tried this once and much to my suprise the engine was considerably quieter
KLJ895W
Re: molyslip
#8 Post by KLJ895W » Wed Feb 25, 2004 10:23 am
Has anyone tried any additives in their diff (not LSD of course)?<br>
David
dmite
slick 50
#9 Post by dmite » Wed Feb 25, 2004 11:26 am
Put it in my kl 650 kawasaki at about 4000km Have ridden that bike half way around Oz A lot of dusty dirt roads included Its now has 65000 km on it and would possibly do it again, have only ever needed to replace one tappet shim because it was getting a bit too tight.The motor is still strong I ride it to work every day as all my cars are in pieces.<!--EZCODE EMOTICON START :rollin --><img src=http://www.ezboard.com/intl/aenglish/im ... s/roll.gif ALT=":rollin"><!--EZCODE EMOTICON END--> I change oil regularly around 1500 km , started out with synthetic but after the big trip changed to mineral. changed the filter every 2 or 3 oil changes.One day I will open it up and then I will maybe able to tell if it worked for sure.<!--EZCODE EMOTICON START 8o --><img src=http://www.ezboard.com/intl/aenglish/im ... s/nerd.gif ALT="8o"><!--EZCODE EMOTICON END-->
alun n
Re: Slick 50
#10 Post by alun n » Wed Feb 25, 2004 11:42 am
The only additive I've put in my axle is sawdust to stop it whining!!<!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/intl/aenglish/im ... /laugh.gif ALT=":lol"><!--EZCODE EMOTICON END-->
Chris Field
Sawdust, do you think...
#11 Post by Chris Field » Wed Feb 25, 2004 11:50 am
It would have the same effect on Mrs F?
anthony rld900r
molyslip
#12 Post by anthony rld900r » Wed Feb 25, 2004 5:11 pm
Strange - haven't seen it for years - used to put it in my Saab 900's, if I can find some I'll try it on the next dolly oil change (been using a 50/50 mix of 20/50 with 15/40 -don't ask why - just thought I'd experiment - runs quieter than on 20/50 and not as thin as 15/40)<!--EZCODE EMOTICON START :rollin --><img src=http://www.ezboard.com/intl/aenglish/im ... s/roll.gif ALT=":rollin"><!--EZCODE EMOTICON END-->
KLJ895W
Re: Slick 50
#13 Post by KLJ895W » Thu Feb 26, 2004 10:16 am
Alun, do you put sawdust in cars you're keeping or just the ones for sale?<!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/intl/aenglish/im ... s/wink.gif ALT=";)"><!--EZCODE EMOTICON END--> <br>
David
alun n
Ermm....
#14 Post by alun n » Thu Feb 26, 2004 10:25 am
.....only joking like! I traded my 'whiner' in to Rimmers many years ago when that sebastian bloke still worked there. So if anyone has bought a recon from them with the case number VA6712.....
sawdust
#15 Post by Dave » Fri Feb 27, 2004 5:07 pm
I thought an alternative was old tights. never known which denier though<!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/im ... /smile.gif ALT=":)"><!--EZCODE EMOTICON END-->
Locked
