Oil pump
Locked
KWM338R
Oil pump
#1 Post by KWM338R » Sun Aug 27, 2006 4:43 pm
I fitted a new oil pump to the Sprint yesterday hoping it would fix my low oil pressure at tickover, it didn't <!--EZCODE EMOTICON START :rolleyes --><img src=http://www.ezboard.com/images/emoticons/eyes.gif ALT=":rolleyes"><!--EZCODE EMOTICON END--> . Anyway the new pump noe interferes with the oil cooler take off, Has anyone else experienced this problem? I ended up removing the takeoff, it looks like the edge against the oil pump will need a flat filing on it. The other thing is now the car runs like a bag of shite. i didn't touch the ignition or fueling so am at a loss. It was running perfectly well before I started tinkering with it<!--EZCODE EMOTICON START >D --><img src=http://www.ezboard.com/images/emoticons/grin.gif ALT=" >D"><!--EZCODE EMOTICON END--> . I checked the timing, spot on, I'll pull the plugs to see if they are fowled up from when I was cranking it to build pressure before firing.<br>
Cheers<br>
DailySprinter
oil pressure
#2 Post by DailySprinter » Mon Aug 28, 2006 7:37 am
you could try new bearings, it will increase pressure. What's the oil presuure, it's not too critical at tickover.<br>
Does it do 40PSI at 3000RPM?
Oil pump drive...
#3 Post by Jon Tilson » Mon Aug 28, 2006 12:25 pm
comes of the distributor. I'd recheck points gap...<br>
KWM338R
Re: Oil pump drive...
#4 Post by KWM338R » Mon Aug 28, 2006 1:24 pm
Thanks Gents, I went back over it last night when I had a bit more time and wasn't rushing about trying to get it finished. Checked the points and timing, both were out. drove it to work this morning and it was alot better, though still had a bit of hesitation when cruising, I'll check again at lunch time. I do have about 45-50 PSI by about 2000RPM so I think all is well, just got a bit nervous about it after seeing my mates big end bearings he took out of his Europa. I didn't change it when I did the bottom end last time,which I normlly do.<br>
Cheers<br>
<p>1979 Dolomite Sprint<br>
1972 TR6 (now breaking for spares to fund the Dolly)<br>
1993 Mazda Protege ($250 Winter Hack)<br>
2000 Mazda MPV (For Sale)<br>
</p><i></i>
DailySprinter
oil pressure
#5 Post by DailySprinter » Mon Aug 28, 2006 6:06 pm
Oil pressure is fine, leave well alone, it's what it should be or there abouts.
KWM338R
cooler takeoff housing
#6 Post by KWM338R » Mon Aug 28, 2006 6:44 pm
Anyone run into clearence issues with the oil cooler takeoff interfering with the oil pump, It wasn't an issue before. <br>
Cheers<br>
</p><i></i>
Locked
Users browsing this forum: Amazon [Bot] and 3 guests
