Investigating noises in the transmission
Nope
Too loud for the speedo cable.<br>
Come to think of it, the car is turning green! <!--EZCODE EMOTICON START :rollin --><img src=http://www.ezboard.com/intl/aenglish/im ... s/roll.gif ALT=":rollin"><!--EZCODE EMOTICON END-->
They do?
What does it sound like? is it a loud, tinny noise?<br>
Y'know, I'll end up rebuilding the bloody car at this rate just to find the damn thing! <!--EZCODE EMOTICON START >D --><img src=http://www.ezboard.com/intl/aenglish/im ... s/grin.gif ALT=" >D"><!--EZCODE EMOTICON END-->
Re: They do?
A spinning noise that varies with speed sort of:<br>
"tik, tik, tik, tik, tik, tik......"
Oh right
Well it's not that then, this is an intermittent clanking noise. Like you say, it would be a consistent clicking if it was the speedo.<br>
I'll disconnect the speedo anyway at some point.<br>
Oh my, I've got one of those air threshners which has a little prop which spins around when you put the blower on.........I wonder .......<!--EZCODE EMOTICON START :eek --><img src=http://www.ezboard.com/intl/aenglish/im ... ns/eek.gif ALT=":eek"><!--EZCODE EMOTICON END-->
Re: Oh right
Girlfriend's ear rings?
Possibly
I'll have to make sure the missus doesn't see them! <!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/intl/aenglish/im ... /laugh.gif ALT=":lol"><!--EZCODE EMOTICON END-->
Re: Possibly
Right, after further investigation and with the help of the mersey tunnel (2 trips <!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/intl/aenglish/im ... /happy.gif ALT=":D"><!--EZCODE EMOTICON END--> ) and having the window down. I have found that the noise only happens when I put my foot down on the accelerator but is intermittent.<br>
But again, it's only in drive. At a stand still I can rev the car quite happily with no noise!<br>
The exhaust is very firm in its position so it can't be that.<br>
This is so strange!
This is so strange!
Re: Possibly
Only in drive??<br>
That sounds like a torque converter issue to me. I hope it isn't.<br>
Jod<br>
Jod<br>
Re: Possibly
Jod,<br>
would you like to elaborate a wee bit more on the torgue converter? Too be honest, I've never heard of it.<br>
Oh hold on, am I right in saying they are used on auto boxes instead of a clutch? If so, mine is a manual.
<p></p><i>Edited by: <A HREF=http://pub52.ezboard.com/bthetriumphdol ... b>AndyS</A> <IMG HEIGHT=10 WIDTH=10 SRC="http://hometown.aol.co.uk/ASkop01/myhomepage/car1a.gif" BORDER=0> at: 27/3/04 5:12 pm<br></i>
Funny that....
I thought we were on an auto quest here too....<br>
My money is on the propshaft....<br>
Does it matter which gear your in,....worse or less bad on bends etc...overdrive or not?<br>
Jon
Jon
Re: Funny that....
Ooops apologies for confusing you all.<br>
The noise is on all gears (intermittently) but only when I use the accelerator. If I back off, the noise disappears. It is more noticeable in first and second. Some times it's very loud, sometimes not.<br>
I also get it if I go over bumps. Thats whats got me thinking it might be the exhaust, but is it very rigid and seems to be in order. There also seems to be vibration too!<br>
Very puzzling.
Very puzzling.
I think I've cracked it.....
Page 50(4) of my haynes.......... "Wear in the kneedle roller bearing is indicated by vibtration or 'clunks' in the transmission,particulary when the drive is being taken up!!"<br>
Well thats exactly whats happening! Is it a difficult job?
Needle rollers....
Ususally make a whiring noise which can be heard with the car in neutral and clutch up. Layshaft and input shaft are then turning but not under much load. In 1st to third gears the noise will be much worse and may be an engine spedd related load whining that reduces when in top gear. It tends not to come and go but be constant. How is your reverse? I ask cos the selctor mounting pin sometimes works loose and lets the reverse cog touch other bits intermitently but this is very rare.<br>
Jon
Jon
