Engine swap number 2...
2F45T4U
George
#16 Post by 2F45T4U » Fri Jul 21, 2006 6:45 pm
I've got a spare manifold here, but no gaskets or o-rings <!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/images/emoticons/wink.gif ALT=";)"><!--EZCODE EMOTICON END--> <!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/images/emoticons/wink.gif ALT=";)"><!--EZCODE EMOTICON END--> <!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/images/emoticons/laugh.gif ALT=":lol"><!--EZCODE EMOTICON END-->
george
gaskets
#17 Post by george » Fri Jul 21, 2006 7:20 pm
think i might have what your'e looking for<!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/images/emoticons/wink.gif ALT=";)"><!--EZCODE EMOTICON END-->
2F45T4U
Re: gaskets
#18 Post by 2F45T4U » Mon Jul 31, 2006 10:56 am
Almost all together. Needs the alternator tensioner fitted (need to modify a tr7 one lost the 1850 part <!--EZCODE EMOTICON START :o --><img src=http://www.ezboard.com/images/emoticons/embarassed.gif ALT=":o"><!--EZCODE EMOTICON END--> ) clutch pack and then it can be fitted <!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END--> <br>
Guaranteed to be more than just be one days work <!--EZCODE EMOTICON START :rolleyes --><img src=http://www.ezboard.com/images/emoticons/eyes.gif ALT=":rolleyes"><!--EZCODE EMOTICON END--> <!--EZCODE EMOTICON START :p --><img src=http://www.ezboard.com/images/emoticons/tongue.gif ALT=":p"><!--EZCODE EMOTICON END-->
Stan Part
Re: 7/1850
#19 Post by Stan Part » Mon Jul 31, 2006 11:28 am
Adam<br>
In all your work with both motors, have you noticed anything significantly different between an 1850 engine and the 2 Litre one.<br>
I have an excellent low miles engine taken from an 1850, has no engine number but I'm told it is an TR7 2.0 litre but where it's already been in an 1850 all the bits have been swapped I would like to confirm it is one or the other.<br>
Is there anything external that you have noticed between the two please, where you could of said, yes this is the TR7 motor and this is an 1850 one?
<p></p><i>Edited by: <A HREF=http://p206.ezboard.com/bthetriumphdolo ... crome>Alan Crome</A> at: 31/7/06 11:29 am<br></i>
dollysteve
Re: 7/1850
#20 Post by dollysteve » Mon Jul 31, 2006 11:31 am
TR7`s have a heater take off on the back of the cylinder head , on the 1850 it has a blanking cover bolted in place.
Stan Part
Re: 7/1850
#21 Post by Stan Part » Mon Jul 31, 2006 11:37 am
Steve where this engine has already been in an 1850 would the pipe been left on (can it come off) or just blanked off (like in an 1850 with the 1850 banking plug) because it isn't needed?
<p></p><i>Edited by: <A HREF=http://p206.ezboard.com/bthetriumphdolo ... crome>Alan Crome</A> at: 31/7/06 11:43 am<br></i>
dollysteve
Re: 7/1850
#22 Post by dollysteve » Mon Jul 31, 2006 12:26 pm
Assuming the TR7 engine had been put in the Dolly complete with TR7 manifold and carbs I would hazard a guess that the heater take off on the head would have been left on.
Stan Part
Re: 7/1850
#23 Post by Stan Part » Mon Jul 31, 2006 1:19 pm
No, this has the 1850 carbs/manifold on so I guess this means another dead end re verification of it being a 2.0 Litre?
If its been swapped....
#24 Post by Jon Tilson » Mon Jul 31, 2006 1:52 pm
Another difference is the flywheels and end plates.<br>
If the dolly end plate is used it needs to have countersunk phillips holding it to the block to clear the fatter flywheel. If its been swapped for 1850 bits then chances are the only way is to measure the bore...<br>
dollysteve
Re: If its been swapped....
#25 Post by dollysteve » Mon Jul 31, 2006 1:56 pm
I reckon Jonners is right then, bore size is the only way. I really can`t understand why someone would go to the trouble of swapping to TR7 power only to strangle it with smaller carbs than it should have.
Stan Part
#26 Post by Stan Part » Mon Jul 31, 2006 2:45 pm
Do you know you have me wondering now if this DOES the 1850 cabs/manifold, it's been so long since I've looked properly at it (though I do turn it over manually now and again).<br>
Guess what I'll be doing when I get home<!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/images/emoticons/laugh.gif ALT=":lol"><!--EZCODE EMOTICON END-->
2F45T4U
#27 Post by 2F45T4U » Tue Aug 01, 2006 11:45 am
If I were to measure the bores I'd take the sump off rather than the head.<br>
Well as of yesterday it's in and it runs! Much better than the last one may I add! Doesn't make as much oil pressure but runs cooler, idles lower and smoother and the best bit... pulls much much better. Only took me an hour of pootling around before I gave in. Saw a 90s' clio with alloys and fart can exhaust and had to have him at the lights <!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END--> <!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END--> <!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END--> No contest, may well be quicker than Richards Sprint, I have no idea how my carbs are set up!<br>
It also makes one awesome noise from the exhaust, the baffles could well of given up <!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END--> <br>
Very happy <!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END--> ...But just 1 month of driving left <!--EZCODE EMOTICON START :( --><img src=http://www.ezboard.com/images/emoticons/frown.gif ALT=":("><!--EZCODE EMOTICON END-->
2F45T4U
Re: .
#28 Post by 2F45T4U » Tue Aug 01, 2006 4:47 pm
It just gets better...<br>
Put the carbs back to base, 12 flats down and it pulls better again!<br>
Then find out after talking to George that I've set my timing 11 degrees out of whack! I'll report back once thats sorted <!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END-->
george
re.
#29 Post by george » Tue Aug 01, 2006 7:49 pm
hows your quest for a 500ci lump going ?
davepoth
Re: re.
#30 Post by davepoth » Tue Aug 01, 2006 10:29 pm
<!--EZCODE AUTOLINK START--><a href="http://www.cadillacperformanceparts.com ... <!--EZCODE AUTOLINK END--><br>
500 bhp on 92 octane petrol...should do the job. <!--EZCODE EMOTICON START :hat --><img src=http://www.ezboard.com/images/emoticons/pimp.gif ALT=":hat"><!--EZCODE EMOTICON END-->
Locked
Users browsing this forum: Google [Bot] and 0 guests
