Worn Piston Ring
No Oil Pressure...
Well I got up this morning with a PMA. I got on really well putting the engine back in, I even got it lined up with the g/box at ther first attempt. <!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END--> <br>
Put on all the necessaries, apart from the rad & hoses. No spark plugs, as I just want to crank the engine over to get the oil circulating.<br>
<!--EZCODE EMOTICON START :eek --><img src=http://www.ezboard.com/images/emoticons/eek.gif ALT=":eek"><!--EZCODE EMOTICON END--> no firkin oil pressure showing on the gauge. I took the tube off the back of the gauge with cloth at the ready, crank it over & nothing came out. So I took one of the oil cooler hoses off and still no oil came out. I know the oil pump is ok & I defo remember putting the oil strainer/pickup in (and yes I did put oil in). <!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/images/emoticons/laugh.gif ALT=":lol"><!--EZCODE EMOTICON END--> <br>
I've packed up for today hoping you guys can come up with suggestions.
<p>Martin<br>
<p>Martin<br>
Carsreunited
Re: No Oil Pressure...
Mine took ages to get oil pressure up last time it was put back in. It did eventually but after 20 or 30 short bursts on the starter with ht system disabled
Dizzy out and turn the hex shaft with a drill save's any wear to the engine.<br>
Put engine to TDC first mark dizzy before removing.<br>
Start by removing the oil pressure switch and proceed with the oil cooler both side's till oil is flowing,<br>
May be a simple oil pick up problem IE (gasket not sealing).<br>
<p>1980 Dolomite SprintV8 (360bhp of TVR AJP V8 Pumping Alloy Coming soon !)<br>
They laugh at me because I am different. I laugh at them because they are all the same!)<br>
</p><i></i>
</p><i></i>
Cheers Scott & Phil<br>
I was just doing what you suggested Phil, before the Grand Prix. I now have a puddle of new oil on the floor, so at least I know the pump is OK. Just going out to put the rest of it back together. Report back later.
<p>Martin<br>
<p>Martin<br>
That seemed to fix it. Bit strange that, as all engine rebuilds I've done before have always given oil pressure on cranking the engine!<br>
Almost got it running, just need to get the ignition timing right. Only thing is, now the starter motor's packed up. <!--EZCODE EMOTICON START :rolleyes --><img src=http://www.ezboard.com/images/emoticons/eyes.gif ALT=":rolleyes"><!--EZCODE EMOTICON END-->
<p>Martin<br>
<p>Martin<br>
Want another starter?<!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <br>
Motor or Solenoid?<br>
Cheers Graeme, I'll investigate further. I think I have a spare somewhere, I'll let you know. <!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END-->
<p>Martin<br>
<p>Martin<br>
Sorted...
...well almost.<br>
Took it out for a quick spin with the rev limiter set to 3k. Temp. didn't go over 85 (not surprising really), got back & had a look under the bonnet for any leaks...none <!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END--> <br>
Went to put it back in the garage & the starter packed up again. <!--EZCODE EMOTICON START >: --><img src=http://www.ezboard.com/images/emoticons/mad.gif ALT=">:"><!--EZCODE EMOTICON END--> I'll get there one day.<br>
5 miles down...495 to go. <!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/images/emoticons/laugh.gif ALT=":lol"><!--EZCODE EMOTICON END-->
<p>Martin<br>
<p>Martin<br>
Re: Sorted...
Got the starter sorted.<br>
I've now covered 160 miles. It's hell with the rev limiter set to 3k rpm. but I'm glad it is as I would have easily over shot it by now with my lead boots. <!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/images/emoticons/laugh.gif ALT=":lol"><!--EZCODE EMOTICON END-->
<p>Martin<br>
<p>Martin<br>
How many RPM
I would have completed more than 500 miles since my engine rebuild, come the weekend, so time for an oil & filter change and re-torque the head.<br>
Since having a rev limiter I've always set it to 6000rpm. I think I'm now going to set it to 6500 as my max. bhp is at 6000, or maybe even set it to 7000. What have you guys got yours set at (those that have) and what are the pros & cons of going as high as 7000 rpm?
<p>Martin<br>
<p>Martin<br>
Carsreunited
Re: How many RPM
I don't have one but I have my shift warning light set at 6400, 6600 and the final oneat 6800rpm on the stack.<br>
On the STR91 you can feel the power falling away at 6500rpm so I haven't really bothered taking it to 7000.<br>
Re: How many RPM
I'm going to give it a try up to 7000 to see if it still makes power, if it falls away after 6500 that's where I'll set it. I know when I went out with Bob K his was set at 7000, running an STR91 cam & seemed to pull all the way.
<p>Martin<br>
<p>Martin<br>
Re: How many RPM
Mine used to easily hit 7000rpm if you let it with the STR91, but then my engine didnt exactly last very long!<br>
stick to 6.5K to be safe IMO unless youve done a lot of bottom end work.
<p><!--EZCODE LINK START--><a href="http://www.smifter1971.pwp.blueyonder.c ... >Smifter's Dolomite Sprint Website</a><!--EZCODE LINK END--><br>
Scary XE powered 1974 Dolomite Sprint Trackday Experiment. Maybe someday soon<br>
2002 Octavia VRS - 20 valves, leather, a turbo and 146mph - Czech it out!! </p><i></i>
