Dashboard loom
Locked
tinweevil
Dashboard loom
#1 Post by tinweevil » Sun Sep 11, 2005 9:42 am
What do I ask the seller of <!--EZCODE LINK START--><a href="http://cgi.ebay.co.uk/Triumph-Dolomite- ... Item">this loom</a><!--EZCODE LINK END--> to establish if it's the early one I need for VA41?<br>
Tinweevil
1972 Spitfire IV<br>
39 anorak points on the Nicholas scale<br>
</p><i></i>
Carsreunited
Re: Dashboard loom
#2 Post by Carsreunited » Sun Sep 11, 2005 9:50 am
If it says 'rocker type' hazard switch then it stands half a chance. I don't know if there were any other differences. I'm sure someone else will confirm.<br>
Silvery
Home Made
#3 Post by Silvery » Sun Sep 11, 2005 4:06 pm
When I got a Sprint/ hl dash for my TC, I got the terminals from someone online and adpated it to suit.<br>
But if you don't have a loom at all, then I can't see why this one would cause any problems. You ought to double check the wiring and make sure the connectors on the harness match where they go to on the loom, but it's a peice of cake to swap pins around in the plugs <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/im ... /smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <br>
IIRC the hazards are on spade/ lucar connectors, so whatever the case if you have them they should wire up fine I'd think. If you don't have hazards, you can either use this opportunity to wire them up, or ignore them and have a reduntant switch.<br>
Basically, at worst you'll have to do a bit of fettling <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/im ... /smile.gif ALT=":)"><!--EZCODE EMOTICON END-->
tinweevil
Re: Home Made
#4 Post by tinweevil » Sun Sep 11, 2005 8:24 pm
Thanks guys. I was referring to <!--EZCODE LINK START--><a href="http://p206.ezboard.com/fthetriumphdolo ... opic">this thread</a><!--EZCODE LINK END--> where Alun said it would not be straight forward to change the dash in VA41 from the late to the early type. I f the one on ebay is the late type I may as well bodge the one thats in the car already to suit the earlier dash (once I find one of those). On the whole tho if I'm going to change the dash I'd rather plug the correct loom in with it than start chopping.<br>
Tinweevil
</p><i></i>
alun n
Re: Home Made
#5 Post by alun n » Mon Sep 12, 2005 12:25 am
The eBay one appears by the description to be the early type. What you would then need is an early and late wiring diagram to find out what pins to put where in the multiplugs and which ones to re-route completely. For instance individual or combined direction flasher indicators, HRW indicator or not, HWL warning light or not, etc etc
<p>1973 Dolomite Sprint<br>
1974 Dolomite Sprint<br>
1977 Dolomite Sprint (Pageant)<br>
1977 Dolomite Sprint (White)<br>
1979 Dolomite Sprint<br>
1979 Dolomite 1850HL<br>
1980 Dolomite 1500HL<br>
1998 Lotus Elise<br>
1999 Alfa Romeo 166 2.5 V6<br>
1999 Alfa Romeo 166 3.0 V6 (well...it was there wasn't it!)</p><i></i>
Locked
Users browsing this forum: No registered users and 4 guests
