5 linking
Locked
SMIFTER
5 linking
#1 Post by SMIFTER » Tue Feb 03, 2004 10:41 am
I'm measuring up my 4HA axle to fit at the moment (which it does quite well).<br>
I was going to reweld some standard dolly mounting points and fit a panhard rod, however the standard dolomite set up isnt exactly perfect.<br>
And my axle already has mounting points for a rwd escort 5 link set up.<br>
For about £250, I can buy all the necessary weld in mounting boxes, adjustable rose jointed link rods and coilover turrets which will result in a very securely fixed axle with good geometry (the spring/damper will act on the axle, not on the trailing arm, the pinion angle will remain constant when the axle moves).<br>
I'm going to measure it up off bother in laws escort to see if it will work and to get an idea of complexity but it should work.<br>
I'm sure the fuel tank and exhaust will need relocating though(poss to a side exit design).<br>
Does anyone know if its been done before on a Dolly?<br>
If not, I might take the plunge and resign myself to not having a working Dolomite this year.
john 16v
re:axle
#2 Post by john 16v » Tue Feb 03, 2004 12:51 pm
is it not possible to fit an independant rear axle off something like a 2.0/2.3 sierra or would this involve major engineering skill!<!--EZCODE EMOTICON START 8) --><img src=http://www.ezboard.com/intl/aenglish/im ... lasses.gif ALT="8)"><!--EZCODE EMOTICON END-->
SMIFTER
Re: re:axle
#3 Post by SMIFTER » Tue Feb 03, 2004 1:56 pm
its got to be possible but probably beyond the skills of a diy mechanic.<br>
A live axle is much easier and probably just as good for circuit use.<br>
I think some kit cars use the Sierra IRS set up though.
SMIFTER
Re: re:axle
#4 Post by SMIFTER » Thu Feb 05, 2004 10:23 pm
5 linking update<br>
Borrowed some escort turrets and link boxes to see how it fits and with a bit of trimming it'll fit easily, too easily in fact - I'm trying to find the catch. <br>
I've decided this is the way to go for the perfect axle location and I'll be investing in a 4-link axle bar kit, coilover damper turrets and a Panhard rod kit from Peter Lloyd Rallying which should set me back about £230.<br>
I'll keep a photo log of the work involved for reference by others.
<p><!--EZCODE LINK START--><a href="http://www.smifter1971.pwp.blueyonder.c ... >Smifter's Dolomite Sprint Website</a><!--EZCODE LINK END--></p><i>Edited by: <A HREF=http://pub52.ezboard.com/bthetriumphdol ... SMIFTER</A> at: 5/2/04 10:26 pm<br></i>
tinweevil
Major surgery.
#5 Post by tinweevil » Fri Feb 06, 2004 2:25 pm
Sorry if I'm teaching my grandma the oeuf trick but:<br>
Somewhere recently I read 'In this class you must have the same basic suspension layout, transmission, bodywork....'. Have you checked you aren't going to fall foul of this? If I'm understanding you right you are changing most of the rear suspension geometry and a few lumps of major structural bodywork to accomodate it.<br>
Tinweevil
peter loyd
#6 Post by Dave » Fri Feb 06, 2004 4:19 pm
Rallying have an interesting second hand board, this being the edge of the valleys some of it may be a little HOT though.
John Skinner
5 Link
#7 Post by John Skinner » Fri Feb 06, 2004 5:27 pm
Should be interesting - definitely the way to go.<br>
Didn't happen to leave a mount for a Watts linkage on it did he??
SMIFTER
Re: 5 Link
#8 Post by SMIFTER » Fri Feb 06, 2004 6:10 pm
Tinweevil - I'm changing from road production to modified class where transmission mods are free. <br>
Sprinting Scrutineers dont check in that much detail unless your in a championship anyway.<br>
John - There isnt a watts linkage mount which is a shame but it could be done.<br>
I think I'll start with a panhard rod though. Softly softly catchee monkey.
Locked
