Last night I receieved a call from a woman calling on behalf of a friend of hers who owns an 1850, she started off by saying that the car had failed it`s MOT on a "Top front suspension bearing", never heard of that before, they don`t have a beaing just the mounting plate sandwiched between 2 bushes and pressed metal washers. I gave her the part numbers of the bushes as I thought this would be the most likeley cause of her friends problem. I don`t really see what else it could be, seems that it` a case of an MOT tester not knowing what he`s dealing with. Anyway. I said I would ask the question to you chaps in case i`m missing something so feel free to tell me my assumptions are wrong.
Top strut mount bearing??????
Re: Top strut mount bearing??????
I'd hazard a guess at it being a corroded turret top; ie where the top strut bears...<br>
I doubt a tester would be able to discern the detail if the bushes had failed?
dollysteve
I guess so. I did say to her that it could be the actual strut top mount had corroded away, although unlikeley as it`s fairly heavy guage metal and I have certainly never seen on rot, not the same can be said for the turret as you say.
or was it top suspension load bearing.. as in the part theat bears the load (strut top, as you've already said!!)<br>
just a thought.<br>
Justyn
just a thought.<br>
Justyn
