ignition timing?
Locked
947T
ignition timing?
#1 Post by 947T » Tue May 31, 2005 11:24 pm
Hello everyone<br>
Just fitted a magnatronic ignition system today and replaced plugs(unipart ones)<br>
All went well and I was pretty proud of myself (not being the mechanical type)<br>
BUT - the engine revs are now higher at idle. Used to be about 800-900 now 1200. Is this to be expected after fitting the new ignition and do I now need to adjust the timing?<br>
The car runs well though.<br>
And for those that answered my last question about the fuel hose replacement, thanks. Replacing that went well too. Replaced all pieces around the carbs. They weren't that bad when I got them off but a bit of planned preventative maintainence never hurt anyone, so they say. I replaced them with some that I bought from Halfords made by Goodyear.
MaddMart
Re: ignition timing?
#2 Post by MaddMart » Tue May 31, 2005 11:30 pm
Trying to think back to when I did mine, I think the timing does advance a bit so you'll need to tweak it back.<br>
Martin
<p><!--EZCODE LINK START--><a href="http://www.dolomitesprint.com/" target="top">www.dolomitesprint.com</a><!--EZCODE LINK END--></p><i></i>
miniman
#3 Post by miniman » Wed Jun 01, 2005 8:01 am
Is this likely to also be the cause of my running-on problem??
Mike Groom
Ignition Timing
#4 Post by Mike Groom » Wed Jun 01, 2005 9:17 am
Yes, you will need to tweek the timing. I have also just fitted a Magnetronic system and I had to rotate my distributor anticlockwise as the timing was out by about 6 degrees (on the timing marks). I only just had enough room as the vacuum advance ended up touching some adjacent components.
miniman
Re: Ignition Timing
#5 Post by miniman » Wed Jun 01, 2005 9:57 am
Has anyone got a timing quadrant knocking around? Seems to be missing from my car...
alun n
Must have one somewhere...
#6 Post by alun n » Wed Jun 01, 2005 10:08 am
...send me your address (mine's in the back of the magazine) and it'll be with you in a jiffy (literally)... nominal donation to Cancer Research or the Woodland Trust
miniman
Re: Must have one somewhere...
#7 Post by miniman » Wed Jun 01, 2005 10:39 am
Thanks Alan, much appreciated. <br>
James Skinner<br>
17 Primrose Way<br>
Chippenham<br>
SN14 6XW<br>
Locked
