Which oil for LSD?
Which oil for LSD?
hi folks<br>
I replaced the rear axle bushes and changed the diff oil on this occasion (simply jacked up the diff at the front when the tie bars where off and let most of the oil pour out).<br>
Now I have a whining of which I'm sure it wasn't there before - not driven much since the buying. It's only audible when holding the speed exactly, no noise on de-/accelerating.<br>
So checked the oil yesterday and I was shocked to find out it's grey already and you can see shiny particles in it <!--EZCODE EMOTICON START :eek --><img src=http://www.ezboard.com/intl/aenglish/im ... ns/eek.gif ALT=":eek"><!--EZCODE EMOTICON END--> The old oil which poured out looked still like honey, so I fear there must be something wrong!<br>
Wrong oil? Used Catrol Hypoy LS (it's an LSD)<br>
Help <!--EZCODE EMOTICON START :o --><img src=http://www.ezboard.com/intl/aenglish/im ... rassed.gif ALT=":o"><!--EZCODE EMOTICON END--> <br>
Benjamin
Benjamin
Re: Which oil for LSD?
I use LSD oil from Jigsaw Racing<br>
Cant remember what make but if you ring Mark at Jigsaw I'm sure he anwser,<br>
Failing that Scott or one of the other Lads I dare say can tell you what oil there use and where from.
<p></p><i>Edited by: <A HREF=http://p206.ezboard.com/bthetriumphdolo ... printV8</A> at: 28/5/05 3:52 pm<br></i>
I use the stuff from Jigsaw aswell but can't remember the name. <!--EZCODE EMOTICON START :rolleyes --><img src=http://www.ezboard.com/intl/aenglish/im ... s/eyes.gif ALT=":rolleyes"><!--EZCODE EMOTICON END-->
<p><!--EZCODE LINK START--><a href="http://www.dolomitesprint.com/" target="top">www.dolomitesprint.com</a><!--EZCODE LINK END--></p><i></i>
Carsreunited
You need xep plate slip diff oil specifically for salisbury's. Mark sells it for around £20 (enough to do the job). What you have used isn't recommended.<br>
However, shiny particles doesn't sound good so have a good look at the internals. Hopefully you caught it in time.<br>
Mark's number is 01536 763799.
ok I'll call and ask them! Car will remain where it is until then <!--EZCODE EMOTICON START :rolleyes --><img src=http://www.ezboard.com/intl/aenglish/im ... s/eyes.gif ALT=":rolleyes"><!--EZCODE EMOTICON END--> <br>
What came to my mind though is that the old oil was only so clear because the car stood for several weeks, so the particles could have been there before and might have sunk down. (But still, ... I have this odd feeling)<br>
cheers,<br>
Benjamin
cheers,<br>
Benjamin
Carsreunited
Give it a good clean down, get the thick stuff in and see how it goes. I take it it wasn't whining before the oil change?
Keith Black
LSD oil
You need Castrol 'LS'....i last bought mine off the shelf at my local motor factors.
Re: LSD oil
>Carsreunited<br>
I'm not sure - but at least I haven't noticed it until after the change so chances are high. Drove only 500 km before but I should had heard.<br>
>Keith<br>
That's what I used: "Castrol Hypoy LS", since this is meant for LSDs and that's also what is told by Haynes!<br>
However the sound made me uncomfortable and then the shiny glitter stuff...
>Keith<br>
Carsreunited
Re: LSD oil
Heres some more info for you.<br>
I've heard a few people advise against the Castrol LSD oil for our diffs. Don't know why its in the Haynes.<br>
<!--EZCODE LINK START--><a href="http://www.pistonheads.com/gassing/topi ... <!--EZCODE LINK END-->
gmsclassics
Re: Castrol LSD oil
I've used Castrol fully synthetic SAF-XA (75W-140) in the Sprintparts (salisbury plate type) LSD in my race car with no ill effects whatsoever. That was on Castrol's technical dept recommendation.<br>
Geoff
Geoff
