Speedo cable (difference between o/d and none o/d types)
Is there any difference in O/D and non O/d 1850 speedo cables?
<p></p><i>Edited by: <A HREF=http://p206.ezboard.com/bthetriumphdolo ... omiteuk</A> at: 26/10/06 4:43 pm<br></i>
Re: Speedo cable
yep<br>
J.
J.
Re: Speedo cable
Explain <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <br>
Mine has snapped, probably becuase of the rate my beast accelerates at <!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END--> On ebay theres a speedo cable thats suitable for Dolomite 1300, 1500 and 1850 with over drive...
Re: Speedo cable
I think I'm right in saying that the o/d cable has a threaded collar at the gearbox end and the non o/d type has a flat flange held in place by a silly fork arrangement on the gearbox. <br>
I don't think they're interchangeable.<br>
Jod
Jod
Re: Speedo cable
I've got a speedo cable mystery at the moment.<br>
My OD box has a flat end, (circular flat dish that is retained by a clamp) speedo cable, with a screw on adaptor for the speedo end.<br>
Both of the speedo cables I've been sent by rimmers (early OD, late OD, sprint) are both totally wrong. One has a wierd plastic lump on the end, the other has a threaded adaptor, neither which suit my box.<br>
I'll stick up a pic later, see if anyone can ID it. <!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/images/emoticons/wink.gif ALT=";)"><!--EZCODE EMOTICON END-->
Re: Speedo cable
<!--EZCODE IMAGE START--><img src="http://www.antchip.com/speedo3.jpg"/><!--EZCODE IMAGE END--><br>
<!--EZCODE IMAGE START--><img src="http://www.antchip.com/speedo2.jpg"/><!--EZCODE IMAGE END--><br>
That's what's on mine. Anyone know what it is? <br>
OT, <br>
<!--EZCODE IMAGE START--><img src="http://www.antchip.com/speedo1.jpg"/><!--EZCODE IMAGE END--><br>
Sometimes stuff just doesn't want to come off <!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/images/emoticons/laugh.gif ALT=":lol"><!--EZCODE EMOTICON END-->
OT, <br>
Re: Speedo cable
Looks like a standard gearbox end terminal to me Lewis. The plastic ends on certain speedo cables clip on to the speedo with a side acting barb (usually 1500 ones and early 1850s from memory) Other cables have a knurled aluminium ring on the back which screws onto the clock. At the gearbox end the item you have photographed is generally clamped onto the speedo drive with a either a separate fork or a figure 8 integral with the cable and a bolt into the housing on either gearbox or overdrive.<br>
I have seen non-overdrive cars with the knurled ring attachment on an angled speedo drive though...
Re: Speedo cable
<!--EZCODE QUOTE START--><blockquote><strong><em>Quote:</em></strong><hr>Other cables have a knurled aluminium ring on the back which screws onto the clock. At the gearbox end the item you have photographed is generally clamped onto the speedo drive with a either a separate fork <hr></blockquote><!--EZCODE QUOTE END--><br>
Yes, that's the one. I removed it off the car as that was all that was left of it. <br>
I can't find a suitable replacement for it though, both Rimmer's OD Sprint cables are incorrect, and I'm slightly baffled.<br>
I've seen OD stag cables on the bay that look exactly the same though! Might pick one up and see if that's what it is.
Re: Speedo cable
<!--EZCODE LINK START--><a href="http://cgi.ebay.co.uk/TRIUMPH-DOLOMITE- ... Item">What is wrong with this one?</a><!--EZCODE LINK END-->
Re: Speedo cable
Bang on! Thanks <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <br>
All...
my overdrive cars have a right angeld drive and the cable fits that end with a knurled ring nut thing. The non o/d cars have the end as in your picture, and a fork type retainer with a single bolt into the box. I dont see how an overdrive can have that type of fitting. At the speedo end all my cars have the plastic push on fitting with a springy plastic clip. The sprints may well be different but Ive never needed to have one off. When Ive upgraded cars to overdrive I was just lucky to have the right cable in stock.<br>
SprintMWU773V
don't get me started
on speedo cables. Had a very long and boring conversation at T.D Fitchetts relating to a speedo cable for my car as they supplied the wrong one but they were insistent it being correct. eventually managed to get one from them that actually works and fits in the holes etc.<br>
length is usually the main difference between cables. An o/d cable is usually slightly longer due to the increased length with the O/D bolted on the back.<br>
Seen loads of cables for 1850's at an autojumble recently, all £1.<br>
Try Fitchetts if you like but it was easier to take the old cable to them to point out the problem/diferences.<br>
You can fit and Angle drive right angle piece to an o/d car but it's pretty unusual. angle drive can be removed usually and a normal cable put on instead.
angles
the angle drive was only fitted to o/d boxes if you have one fitted to a non o/d box it's not a standard fitting<br>
iirc the three rail box had a screw fitting for the cable<br>
and the single rail a fork & bolt <br>
i suspect that some second hand items are fitted to some cars which is why some non o/d boxes will have an angle drive<br>
