Not having a draw hammer to remove the pump, can I do it without it, by improvisation? Can anyone talso tell me what is the difference between the two tools supllied by Rimmer, apart from cost, as one is a budget version. Is the one pictured in the catalogue the dearer one?<br>
Appreciate some help.<br>
Chris T
1850 Water Pump
Re: 1850 Water Pump
Took a six vane pump out of Sprint lump in 10 mins at the weekend with no slide hammer. Locked the jackshaft, with a bar, yes the timing cover was off, undid the water pump bolt, taking care that its a left hand thread, put a penny washer under the bolt and did it back up, then used two levers as best you can either side (a couple of pry bars with assorted bits and pieces) and just pushed down on the handles. Pop, one pump out, including the cage.<br>
Ben.<br>
p.s. That the engine was out and I'd already taken the head off does make it a wee bit easier.....<!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/intl/aenglish/im ... /happy.gif ALT=":D"><!--EZCODE EMOTICON END--> But I have taken the pump out in situ in the same manner, just a bit more swearing...<br>
<!--EZCODE LINK START--><a href="http://www.bodgerben.com" target="top">bodgerben</a><!--EZCODE LINK END--><br>
Ben.<br>
Re: 1850 Water Pump
... and if the cage doesn't come out - what then?<br>
<!--EZCODE EMOTICON START :o --><img src=http://www.ezboard.com/intl/aenglish/im ... rassed.gif ALT=":o"><!--EZCODE EMOTICON END--> <br>
speedracer
<p><!--EZCODE LINK START--><a href="http://www.triumphowners.com/2">1975 Dolly Sprint</a><!--EZCODE LINK END--></p><i></i>
speedracer
