Camshaft identifying?
I have now taken off the cam cover to see what camshaft I have.<br>
The following numbers are stamped on the shaft of the camshaft - Stan Part - 4/2 - MC 25229 - 88 - 3121 - 32<br>
ANY HELP???<br>
The yellow "Rusty" (DLB 665 T) has the Weber 45s and apparently this has a Stage II head?<br>
Regards<br>
ANDREW<br>
BTW - If you have not seen the sorry state of this Dolly have a look at http://www.chesney.org (then click on Dog5)
<p></p><i>Edited by: <A HREF=http://p206.ezboard.com/bthetriumphdolo ... omiteuk</A> at: 19/10/06 12:46 pm<br></i>
ANY HELP???<br>
Regards<br>
ANDREW<br>
Re: What Shaft?
Andrew - the all important number is stamped on the end of the camshaft nearest the bulkhead. You may need a mirror to read it unless the engine is out.
<p><!--EZCODE LINK START--><a href="http://www.aqpd91.dsl.pipex.com/" target="top">Mad Mart's Website</a><!--EZCODE LINK END--></p><i></i>
Re: What Shaft?
Dear Mart<br>
Thank you - I'll have a look tomorrow.<br>
Regards<br>
ANDREW
Regards<br>
ANDREW
Re: What Shaft - KCDM S2?
Dear All<br>
I have now got the correct number off the camshaft:-)<br>
It is KCDM S2<br>
Does this mean anything????<br>
ANDREW<br>
It is KCDM S2<br>
ANDREW<br>
Carsreunited
Sounds like it could be a Kent Camshaft?? The last part of it seems to match the type name for it.<br>
Kent DMS2, power band of 2500-7000        for Fast Road/Rally use.<br>
Duration is 304 degrees, valve lift is 0.376" timing given as 46/78-78/46.<br>
Scott
Scott
And guess what the KC stands for ???<!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/intl/aenglish/im ... /happy.gif ALT=":D"><!--EZCODE EMOTICON END-->
Carsreunited
And I was feeling so smug until you pointed that out<!--EZCODE EMOTICON START :o --><img src=http://www.ezboard.com/intl/aenglish/im ... rassed.gif ALT=":o"><!--EZCODE EMOTICON END-->
Scott, where do you get your cam specs from. I've looked on the Kent Cams website but can't see them there.
Carsreunited
They are in my brain. Advantages of having a photographic memory. Not all that its cracked up to be since digital technology came along.<br>
<!--EZCODE LINK START--><a href="http://www.triumphowners.com/resources. ... tID=111412" target="top">www.triumphowners.com/resources.cgi?par ... <!--EZCODE LINK END--><br>
There are some other handy things in the rsources section which are well worth checking out.<br>
Scott
Scott
Dear Scott<br>
With this camshaft and a pair of 45 DCOEs, I should see some improvement???<br>
BTW, I guess (all being well) this is a weekend job.<br>
I have the head with the KCDMS2 cam in situ. Are there any special tools need to cahnge the head - it's been some 20 years ago I did this!<br>
Whilst on the subject, is there a special head gasket I need and could anybody give a few "Tricks & Tips" they have had whilst changing a head.<br>
ANY suggestions would be great.<br>
ANDREW
ANDREW
Yea, seen that. What can you tell me about KC D355 then ?<!--EZCODE EMOTICON START : --><img src=http://www.ezboard.com/intl/aenglish/im ... ohwell.gif ALT=":"><!--EZCODE EMOTICON END-->
Carsreunited
Re: What Shaft?
Mart.<br>
All I can tell you is that it isn't on the list.<!--EZCODE EMOTICON START :rollin --><img src=http://www.ezboard.com/intl/aenglish/im ... s/roll.gif ALT=":rollin"><!--EZCODE EMOTICON END--> C'mon what were you expecting?<br>
Andrew.<br>
There will definitely be a noticeable difference and that will be that it is going to run pretty rough until you get it set up professionally on a rolling road. They will probably have to change needle sizes etc to suit your cam combination and also to a certain extent what you want from the engine. <br>
Once set up I reckon you could see a 30-40 bhp power increase over standard but this will be at the expense of below 3k rpm pull. Over that figure it will be alot of fun.<br>
Are the 45's off of the yellow essex car or were they on your engine originally?<br>
Scott
Andrew.<br>
Scott
Re: What Shaft?
Dear Scott<br>
The head and 45s are off the "Yellow Essex" so this should already be jetted.<br>
I am in two minds to swap the whole engine from "Yellow Essex" to mine. I think I will stick with the head only and see how that goes.<br>
Apparently, the Yellow Essex has a lightened/balanced crank and flywheel. I can get is running as the Yellow Essex has all the hoses and wires cut (been vandalised).<br>
Any advice?? Do I swap the lot or just the head and carbs?<br>
ANDREW
ANDREW
Carsreunited
Re: What Shaft?
Andrew,<br>
I wouldn't like to say. It sounds better than I originally thought as I'd assumed that the cam had come from the blue essex and the 45's from your car. (For some reason I thought the 45's on the yellow essex had been nicked.) As you say, they should have been matched by the PO.<br>
If I was in your shoes, I'd have the yellow essex engine cleaned up and rebuilt with the parts you have. Its been standing a while (how many years?) I would personally want the re-assurance that everything was fresh and not going to leave me stranded. Also, god knows what those kids in Grays have chucked down the oil filler cap whilst wrecking everything else!<br>
Scott
Scott
