It is currently Wed Apr 21, 2021 11:01 pm
Post new topic Reply to topic  [14 posts ]
PostPosted:Fri Jan 29, 2021 1:35 pm
TDC Spares Officer
I am in the process of digitizing all of the templates that I have with the ultimate aim of allowing users to download and print them out 1:1 for their own use, cut them out, stick them to a panel etc...
This may take a while, I have a lot of templates!!
I will try and update this post accordingly over the coming weeks.
Instructions for printing the pdf templates:
Download and open the appropriate pdf file, some larger pieces may be spread across two pages/files.
To print ensure that you select print Actual Size
When you have printed the file you can verify the size by measuring the white and black Scale, each block is 10mm long by 5mm wide, if this is correct then the file has printed to the correct sizing.
File comment:Headlamp support panel spacer brackets
Headlamp Support Panel Brackets v1.pdf [1.4MiB]
Downloaded 62 times
File comment:Headlamp Gasket Half Moon Part # 627242
Headlight Gasket Support v1.pdf [1007.9KiB]
Downloaded 58 times
PostPosted:Fri Jan 29, 2021 1:59 pm
Brilliant idea!! Appreciate the time and effort this will take, but really useful.
One tiny ask/suggestion - can you write the metal thickness on the template. Will save a lot of time trying to measure thickness, I know there will be standard thicknesses for body and "chassis" parts but I can never remember!
Roger
1971 Stag Auto White
PostPosted:Fri Jan 29, 2021 2:08 pm
TDC Spares Officer
Roger
Good idea, I'll do that, thanks Roger.
 Post subject: Hmm.....
PostPosted:Sat Jan 30, 2021 1:42 pm
This is quite an undertaking.
Well done James :thumbsup:
PostPosted:Sat Jan 30, 2021 1:48 pm
james what a good idea...let us know how progress is going...deserves a big pat on back and well done
PostPosted:Mon Feb 01, 2021 8:13 am
Can I have some Allegro templates as well?
PostPosted:Mon Feb 01, 2021 9:50 am
TDC Spares Officer
I am sure that the Allegro owners club will be very happy to oblige Jeroen! :lol:
TDC Spares Officer
First template uploaded, let me know how you all get on
PostPosted:Fri Feb 12, 2021 10:04 am
TDC Spares Officer
Announcements:
In the process of writing the instructions for the Support panel brackets
Jacking Points - original and Club sill modified
Jacking Pads
All to be uploaded Thursday
Version History:
12/02/21 - Uploaded Headlamp Support Panel Brackets V1
PostPosted:Mon Apr 05, 2021 11:36 am
Brilliant Idea!
PostPosted:Mon Apr 05, 2021 8:59 pm
i was making a headlight suround panel today and thought it would be easier if there was an online template.
Keep up the good work James
PostPosted:Tue Apr 06, 2021 6:47 pm
TDC Spares Officer
Thanks chaps, I'm still in the process of working through them. It's taking longer than expected, mainly due to having to teach myself AutoCad!
PostPosted:Sat Apr 10, 2021 3:10 pm
You could also try some TR7 ones!
Russ Cooper
Dursley
UK
PostPosted:Sat Apr 10, 2021 8:40 pm
I've been using the older style CAD.... Cardboard Aided Design.
Display posts from previous: Sort by
Users browsing this forum: Bing [Bot], Google [Bot], SEMrush [Bot] and 3 guests
