Downloadable templates for repair panels
James467
TDC Sprint Registrar
#1 Post by James467 »
I am in the process of digitizing all of the templates that I have with the ultimate aim of allowing users to download and print them out 1:1 for their own use, cut them out, stick them to a panel etc...
This may take a while, I have a lot of templates!!
I will try and update this post accordingly over the coming weeks.
Instructions for printing the pdf templates:
Download and open the appropriate pdf file, some larger pieces may be spread across two pages/files.
To print ensure that you select print Actual Size
When you have printed the file you can verify the size by measuring the white and black Scale, each block is 10mm long by 5mm wide, if this is correct then the file has printed to the correct sizing.
Headlamp Support Panel Brackets v1.pdf
Headlamp support panel spacer brackets
(1.4 MiB) Downloaded 737 times
Headlight Gasket Support v1.pdf
Headlamp Gasket Half Moon Part # 627242
(1007.9 KiB) Downloaded 685 times
marshman
Re: Downloadable templates for repair panels
#2 Post by marshman »
Brilliant idea!! Appreciate the time and effort this will take, but really useful.
One tiny ask/suggestion - can you write the metal thickness on the template. Will save a lot of time trying to measure thickness, I know there will be standard thicknesses for body and "chassis" parts but I can never remember!
Roger
1971 Stag Auto White
James467
#3 Post by James467 »
marshman wrote: Fri Jan 29, 2021 1:59 pm Brilliant idea!! Appreciate the time and effort this will take, but really useful.
Roger
Good idea, I'll do that, thanks Roger.
Hmm.....
#4 Post by sprint95m »
This is quite an undertaking.
Well done James :thumbsup:
tamtrucks
#5 Post by tamtrucks »
james what a good idea...let us know how progress is going...deserves a big pat on back and well done
#6 Post by soe8m »
Can I have some Allegro templates as well?
James467
#7 Post by James467 »
soe8m wrote: Mon Feb 01, 2021 8:13 am Can I have some Allegro templates as well?
I am sure that the Allegro owners club will be very happy to oblige Jeroen! :lol:
James467
#8 Post by James467 »
First template uploaded, let me know how you all get on
James467
#9 Post by James467 »
Announcements:
In the process of writing the instructions for the Support panel brackets
Jacking Points - original and Club sill modified
Jacking Pads
All to be uploaded Thursday
Version History:
12/02/21 - Uploaded Headlamp Support Panel Brackets V1
GIX 7
#10 Post by GIX 7 »
Brilliant Idea!
TrustNo1
#11 Post by TrustNo1 »
i was making a headlight suround panel today and thought it would be easier if there was an online template.
Keep up the good work James
James467
#12 Post by James467 »
Thanks chaps, I'm still in the process of working through them. It's taking longer than expected, mainly due to having to teach myself AutoCad!
dursley92
#13 Post by dursley92 »
You could also try some TR7 ones!
Russ Cooper
Dursley
UK
TrustNo1
#14 Post by TrustNo1 »
James467 wrote: Tue Apr 06, 2021 7:47 pm Thanks chaps, I'm still in the process of working through them. It's taking longer than expected, mainly due to having to teach myself AutoCad!
I've been using the older style CAD.... Cardboard Aided Design.
naskeet
#15 Post by naskeet »
Back in 1994, when I was still officially registered as unemployed, I took a Konver Scheme funded, City & Guilds course in AutoCAD 12, at Chelmsford College of Further Education, but I have never since had the opportunity to use AutoCAD!
https://cordis.europa.eu/programme/id/REG-KONVER-2
https://hansard.parliament.uk/Commons/1 ... nverScheme
Regards.
Nigel A. Skeet
