Window Seals
Edin Dundee
Window Seals
#1 Post by Edin Dundee »
Where's the best place to buy them (assuming they are still available)?
I'm in particular need of the rubber surrounds on the front quarterlights.
Bill,.........
#2 Post by sprint95m »
Is it the channel type seal that the glass slides up and down in, that you require?
If so, buy it from T2000 specialist Chris Witor, since he sells the correct profile for Dolomites (same as 2000/2500).
mahony
Re: Window Seals
#3 Post by mahony »
Edin Dundee wrote:Where's the best place to buy them (assuming they are still available)?
ive recently fitted front quarterlights which are from rimmers,they fit very well and are very similar quality to the originals,i have also new outer weather strips from rimmers which i have not fitted yet but they also seem of reasonable quality. :)
Edin Dundee
Re: Window Seals
#4 Post by Edin Dundee »
Thanks guys, I'll try Rimmers for the quarterlight seals - and then see where the rest of the windnoise comes from!
Thanks for Witor tip, I've already bookmarked his site and noticed the channel thingy, good to hear it verified.
