Sprint Lumenition Magnetronic Ignition
tr7jim
#1 Post by tr7jim »
Hi,
Can anyone tell me if its possible to fit the Magnetronic kit to the Sprint Distributor 44D4 and which kit is it.
I think it's MTK 007 which is for 45D4, is the difference between these two the lower distributor cap arrangement.
Thanks in advance
Jim
Reg
Re: Sprint Lumenition Magnetronic Ignition
#2 Post by Reg »
Hi Jim.. MTK007 is the correct one, I have one in my Sprint..fits lovely and is a good choice. If you have an inline ballast resistor you will need to extend the positive wire to the fusebox to get a constant 12volts. Don't know of the difference between the two dizzys. Two wires, Black to the coil..Red to the fusebox.. sorted. :)
tr7jim
#3 Post by tr7jim »
Thanks for that Reg,
I was convinced that was the one Rimmers are selling and at present these kits are on sale on ebay for any other interested parties.
Also thanks for the advance on fitting the kit.
Jim
tangocharlie1
#4 Post by tangocharlie1 »
Lumenition also do a Coil to match the kit i have one fitted to my sprint and it is blue in colour, it feels much smoother few the rev range then the lucas ones. Fitting as per Reg's instructions.
1973 Triumph Dolomite Sprint
1972 Triumph Stag
1973 Triumph TR6
schuey57
#5 Post by schuey57 »
just found this thread, im also thinking of fitting the magnetronic, does the plastic ring which fits over the dist shaft have a specific cut away in order for it not to move as my shaft has no cam profiles.
miniman
#6 Post by miniman »
A note of caution on this. When you fit the kit, you screw the mounting plate into the dizzy with a single screw. I and others have found that it doesn't quite hold the plate down tightly enough and this leads to a random and annoying misfire / poor running / not running at all. All it needs is a tiny spring washer between the two and all is well.
schuey57
#7 Post by schuey57 »
hi there, how does the plastic ring with the magnets fit over the shaft, does it have a plastick tongue to fit in the shaft groove, like a woodruf key.
or does it rely on your dizzy having the points style cams to secure it?.
Chris
schuey57
#8 Post by schuey57 »
distributer shaft.jpg (46.64 KiB) Viewed 7159 times
schuey57
#9 Post by schuey57 »
magnet ring.JPG (8.67 KiB) Viewed 7149 times
schuey57
#10 Post by schuey57 »
I bought the magnetronik (007) but my distributer base plate is the wrong one. I think i need the "points" base plate
any 1 have a spare I can purchase
Chris
ham204
#11 Post by ham204 »
Reviving this thread as I wish to know which coil suits the MTK007?
And does it have to be stirred not shaken ? :D
1972 Spitfire MK IV
1972 Stag
1980 Sprint
1962 Land Rover Series 2a
1983 Land Rover Series 3
1995 Suzuki Samurai SJ413
tangocharlie1
#12 Post by tangocharlie1 »
I used this coil but you do NOT need the in-line ballast resisitor that comes with it.
http://www.moss-europe.co.uk/ignition-c ... -lms3.html
1972 Triumph Stag
1973 Triumph TR6
ham204
#13 Post by ham204 »
tangocharlie1 wrote:I used this coil but you do NOT need the in-line ballast resisitor that comes with it.
ah, good - because I just ordered the MS4
Cheers!
1972 Spitfire MK IV
1972 Stag
1980 Sprint
ham204
#14 Post by ham204 »
I fitted my Magnetronic Ignition yesterday. The instructions say that there must be a gap of around 1.5mm between the module and the plastic cap. However if I push it down, the cap is flush with the module. How can I ensure the 1.5mm gap?
1972 Spitfire MK IV
1972 Stag
1980 Sprint
