Tyres
KWM338R
Tyres
#1 Post by KWM338R »
I would like to get a new set of tyres for autocrossing next season but cannot find a decent set on this side of the pond that fit my needs 185/65 13 with a treadware around 180-200. In order to stay in a street tyre class the tyres have to have a treadware rating greater than 140. On US tyre websites this number is listed as UTQG then the number, the lower the number the stickier the tyre. My Yokohama AO48's for example have UTQG 60 rating. Do tyres in the UK have this number on the sidewall? I'm assuming all tyres come from the same factories. Where is a good place to get good tyre info and a selection of tyres in 13" size in the motherland?
Re: Tyres
#2 Post by Mad Mart »
Hi Mark
I was looking at 185/65/13 tyres but there weren't many around in that size.
http://www.blackcircles.com
http://www.mytyres.co.uk
http://www.etyres.co.uk
http://www.tyres-online.co.uk
zombeh
Re: Tyres
#3 Post by zombeh »
KWM338R wrote:Do tyres in the UK have this number on the sidewall?
Most of them do (as most of them are also sold in the US) some tyres that aren't available over there don't have those markings as they're not needed anywhere else so they don't bother to put them through the testing to work out what it would be.
I've not seen anywhere selling tyres that tells you what the treadwear is.
KWM338R
Re: Tyres
#4 Post by KWM338R »
Thanks Gents,
looks like if I want to stay in the street class I'm going to have to go to a 14" rim, that gives me a couple of options for decent tyres over here. That leaves me with another problem, where do I get 14" wheels stateside with 3.75"PCD? I think tr7 and 8's had 13" as standard.
Re: Tyres
#5 Post by Mad Mart »
Can you run 15"? MGFs have the correct PCD iirc. I think Geoff Sparks has them on his track Sprint.
Offset is 30-35mm.
KWM338R
Re: Tyres
#6 Post by KWM338R »
Hello Mart,
I believe I can run 15", it's pretty informal and being such an unusual car here I don't think anyone would care that it is running oversize wheels. My only concern would be rubbing, though I do have a big hammer. Are MGF wheel easy to get hold of? I would have to have a set sent over if nothing turns up locally.
Oli_88
Re: Tyres
#7 Post by Oli_88 »
I have a set of 14" Compomotives on my car, so they do exist and pop up on ebay quite often.
Though that said I can't find any at the moment. :roll:
Typical.
Re: Tyres
#8 Post by Mad Mart »
Loads on ebay UK and pretty cheap. Shouldn't be too expensive to send across the pond.
I don't know about clearance though. Perhaps others on here have tried them?
ToledoZombie
Re: Tyres
#9 Post by ToledoZombie »
Would the studs need to be changed to fit the new nuts if MGF wheels are fitted?
DavePoth
Re: Tyres
#10 Post by DavePoth »
You'll struggle to find anything in the US with that PCD I should think, the last car to get exported with it would have been the Austin Marina!
Maestro wheels would be 14" steels which might work.
KWM338R
Re: Tyres
#11 Post by KWM338R »
I have found a set of sticky 205/60-13" tyres over here. anyone know if these will fit under the rear arches if I roll (or more likely pound with a hammer) them?
I know this is at the limit of the rim width, but beggars can't be choosers.
