DF
Re: My new track project
#91 Post by DF »
photobucket fantastic :wary:
DF
#92 Post by DF »
A little update ,,
Have been fitting the gartrac 4 link body box's and axle brkts ,
I wasn't happy with the gartrac box's as i want to run the shocks off the top of them and i want to run
my axle location off both of them :wink:
Gartrac one not wide enough
my mock up
few bits cut
mine against the gartrac
on the axle with a shock mounted
Tacked on
and all lined up perfect 2 deg nose down on the diff 8)
Gartrac have made my 4 link bars i had them made at 565mm eye to eye,
I have also fitted the body box's as far out as possible,(no piccys as yet ,
My :idea: is if you hold a bar out in front of you shoulder width apart its very stable when some one grabs
it at the ends unlike when holding it more central ,, :thumbsup:
DF
#93 Post by DF »
Inbetween decorating today i managed to get one of the 4 link brkts welded in and put a body brace in
The edge of the brace will tie in with the inside brace hopefully tommorow if i finish papering :?
And a few more bits turned up with the postie
These are for my mumford link
tinweevil
#94 Post by tinweevil »
Mumford link, not heard of that before. Thanks DF, I do like learning stuff.
Yes.....................
#95 Post by sprint95m »
Me too :D .
DF
#96 Post by DF »
Thats ok :D
Im going to try this link it may work it may be a pile of scrap metal :?: who knows
The thing with the watts link is as you lower the car the roll center goes UP,
With the mumford link its a bit different :lol:
Did a bit more today
Made a couple of towers for one of the 4 link brackets
This ties in with the box under the car,
Just got to do the other side tommorow now,, more sunburn :suntan:
Also started on one of the box's
#97 Post by DoloWIGHTY »
Slap on that sun cream Darren, coming along lovely that is. :thumbsup:
mbellinger
#98 Post by mbellinger »
Lovely work as ever Darren.
Martin.
2021 Dacia Duster 1.3 TCe
1963 Austin A40 Rally Car
tinweevil
#99 Post by tinweevil »
That line of welding is just art.
#100 Post by JPB »
That is indeed a very pretty weld. But then the general standard of the work as well as the thought and care going into it is extraordinarily high. I'd go so far as to say that the boundaries really are being pushed aside by this whole, amazing build. 8)
DF
#101 Post by DF »
Thanks for the comments guys,
One bit of advice which i got told from an old chap very good welder ! is
Get some decent welding wire im using murex dont use the cheap machine mart stuff :snivel:
i also take the wire out of the mig when not using it and put it in the airing cupboard, as it does get just a
little bit of dampness on it and maybe some contamination, no problem this weather though, !!!!
DF
#102 Post by DF »
Finished the box's today,
The bit of rear seat cush area ;drivers side; im going to mod as i want to fit a diff cooler and pump
Also behind drivers seat area for the gbox cooler and pump,
But for now its onto the shock towers and im starting fab work on the mumford link,
Also the boot floor is coming out as i have a cunning plan :?:
#103 Post by xvivalve »
If you can get the boot floor out in one the TLC would likely bite your arm off for it unless you intend to later put it back...
DF
#104 Post by DF »
xvivalve wrote:If you can get the boot floor out in one the TLC would likely bite your arm off for it unless you intend to later put it back...
Its not going back in so will try my best
TLC :?: :?:
#105 Post by DoloWIGHTY »
DF wrote: TLC :?: :?:
TLC = David;
memberlist.php?mode=viewprofile&u=79
Been absent for a while from the forum, if you need to contact him I am sure I have an email address for him.
