The Little White Tolly
Lord Tolly
Re: The Little White Tolly
#91 Post by Lord Tolly »
Well now the Volvo has now been sold and is not in front of my garage doors contailing the Tolly I was able to wheel the Little White Tolly out and do a bit more to its new heart.
waterpump is now fitted back just waiting now for some gaskets ,nuts and bolts and then to try and sort out a engine hoist.
Also waiting for the her new clutch to turn up from one of my works old stock collection
:D
Lord Tolly
#92 Post by Lord Tolly »
Engine hoist has now been aquired and erected in the back yard.
weather permiting engine should be out by the end of this weekend :D
Lord Tolly
#93 Post by Lord Tolly »
Well........
Weekend work never happened due to me and my good lady having to babysit our grandaughter due to the arrival of this little fellow....
weighing in at 9lb 4oz Jayden Robert Neal arrived as little brother to his big sister we are babysitting :D :D :D :D :D :D :D :D :D :D :D :D :D :D
sprint1976
#94 Post by sprint1976 »
he's gorgeous congratulations jannette :D
Lord Tolly
#95 Post by Lord Tolly »
sprint1976 wrote:he's gorgeous congratulations jannette :D
Cheers but who is Jannette???
sprint1976
#96 Post by sprint1976 »
me lol
Lord Tolly
#97 Post by Lord Tolly »
oh I see lol :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Lord Tolly
Little White Tolly Good Day's Progress
#98 Post by Lord Tolly »
Well today me and the wife decided we will attack the tolly engine removal.
After about 2 hours the so called TR7 engine was out :D
whilst Leisa was cleaning up the engine bay I decided to have a look at why the engine suddenly just died when she turned the key the wrong way so with my trusty torque wrench and 1"1/2 impact socket on the crank bolt I expected the worst.....but no the engine turned over fine :D :D :D :D :D :D
Then I raised the engine up to remove the sump and oil pump see if anything in there was to blame......apart from some very gungy oil and crud nothing then removed the rocker cover and nowt looked out of place there either.
all I can think of now is somthing must of jammed round the flywheel.
So my dilema is this...... do I refit this engine or go down in size to the 1850 I have cleaned down?????
DoloWIGHTY2
#99 Post by DoloWIGHTY2 »
Re-fit it, it is a known good engine.
#100 Post by JPB »
I'm confused here Glenn. What makes you think that it's not a TR7 engine? If that's the case, then both must have the same capacity and in either case I'd agree with Alan; better the devil you know, etc.
But before shoving it back in there, go through everything in great detail in case there's something likely to cause it to stick again once fitted.
Lord Tolly
#101 Post by Lord Tolly »
sorry John
the engine I have just taken out of the car is a TR7
the replacement I got was a 1850 which is what I have cleaned up to go back in.
I have looked hard at the TR7 lump and all seem's ok.
no nasties top and bottom of the engine so im thinking some how the starter must of cooked itself
Oli_88
#102 Post by Oli_88 »
AFAIK, starters aren't meant to sit at the usual idle speed of 850rpm even if accidentally for just a second... Personally, I'd be tempted to swap the starter and try it again.
Lord Tolly
#103 Post by Lord Tolly »
my thoughts exactly at the moment, quite a relief really the engine appears to have survived the day :D :D :D
worst case senario at least I now have a freshly painted cleand down 1850 on standby if things go belly up.
Purplebargeken
#104 Post by Purplebargeken »
Good position to be in. Although I hope that a starter swap sorts it out.
Fingers crossed mate.
Lord Tolly
#105 Post by Lord Tolly »
Cheers Ken.
Not only that someone gave me a while back yet another 7 engine for free so I will have plenty of spares to fix it with lol
Now the plan at the moment is rub down the engine bay, paint the engine and engine bay, replace all nuts and bolts with stainless and refit with new clutch and finally get rid of the noisey release bearing :D
