1974 Norwegian sprint
Re: 1974 Norwegian sprint
#16 Post by Jon Tilson »
I would shift your raids away from Rimmers.
I get water pump kits from Fitchetts or Robsport who both do the seal without the graphite ring.
Norwegian sprint
#17 Post by Norwegian sprint »
Jon Tilson wrote:I would shift your raids away from Rimmers.
Thanks alot........ :D
Here some pics of me working sprint.... :wink:
engine cleaned.jpg (146.94 KiB) Viewed 3684 times
floor front.jpg (111.94 KiB) Viewed 3680 times
floor back.jpg (118.46 KiB) Viewed 3680 times
#18 Post by soe8m »
I only see a sprint. :D
Norwegian sprint
#19 Post by Norwegian sprint »
soe8m wrote:I only see a sprint. :D
And I am the spirit that breathes life into upcoming Norwegian sprint. :twisted:
Take a look at this ass...... :woohoo:
speed ass.jpg (76.04 KiB) Viewed 3662 times
straylight
#20 Post by straylight »
so you ate the lettuce you were growing near the water pump ?
Norwegian sprint
#21 Post by Norwegian sprint »
now ordered from robsport..... and new connector tube. :nodding: :thumbsup:
Do i have to lower the suspension to allow lifting the complete engine/gearbox out? And the exhaust downpipe???? Hope i can leave that on the manifold :|
DavePoth
#22 Post by DavePoth »
It can be pulled out with the suspension still attached - but you'll need to lift the front of the car to get enough of an angle.
Many people prefer to remove the car from the subframe - lifting the body off of the suspension and then pulling the engine, gearbox and front axle clear from underneath.
Norwegian sprint
#23 Post by Norwegian sprint »
DavePoth wrote:It can be pulled out with the suspension still attached - but you'll need to lift the front of the car to get enough of an angle.
Ok. I think i`m going to lift the front of the car then. I want to keep it on wheels.
#24 Post by Jon Tilson »
Or you can pull the engine box and exhaust downpipe out together on a crane....
Just disconnect the propshaft and exhaust from the downpipe...and clutch slave from gearbox....just leave it dangling....speedo cable and various other little fiddly things like earth strap and starter cables...
Norwegian sprint
#25 Post by Norwegian sprint »
Hard job restoring wood door panel :? .......Use broken piece of glass, to scrape off the old cellulose.
....and yes....i like to eat the green lettuce side of my beer :mrgreen:
Cheers 8)
wood panel.jpg (122.73 KiB) Viewed 3452 times
matienzo
#26 Post by matienzo »
I thought Norwegians were quite tall? There's a mini cafe-racer meet happening on your window ledge!
Steve and Nic
Larger garage needed
straylight
#27 Post by straylight »
as long as you stick to drinking the tuborg and not the laquer/thinners in the other bottles. :)
I enjoyed the hell outta doing he woodwork ! such a nice, simple, achievable job with awesome results at the end.
you are doing great work here, excellent photos.
stu
Norwegian sprint
#28 Post by Norwegian sprint »
Hi.....Cheers 8)
Thanks alot for the feedback.......... :bluewave:
Soon the car is ready for the welder/painter man :wink:
roof left back.jpg (86.42 KiB) Viewed 3263 times
Front stripped.jpg (126.83 KiB) Viewed 3266 times
Norwegian sprint
#29 Post by Norwegian sprint »
Hello again :wink:
Where can i buy this repair panels?
Flyfisherman
#30 Post by Flyfisherman »
according to the parts book - these are not avaiable as individual parts as they are as one piece - inner front valance
http://www.rimmerbros.co.uk/Item--i-814535
I would contact:
Geoff @ Winsinternational - +44 1342 327018
Fitchetts +44 1952 619585 / 620434
Quiller Triumph +44 20 8854 4777
Regards
paul.
